05 fxdi
Old Dec 31, 2012 | 12:17 PM
ght1009's Avatar
ght1009
Thanks fellow brothers and may you all have a great and safe New Years.
Old Dec 31, 2012 | 05:39 PM
truckerdave's Avatar
truckerdave
senior experienced all-knowing leader of the unwise
My 05 was carburetted. Cam chain tensioners would have went out by 40,000, changed to gear drive. A lot of the 05 bikes for what ever reason had compensator nuts that came loose but this would have been in the first few thousand miles. Mine did. The aluminum shifter lever shaft on the tranny got loose on the splines and had to be replaced. This is common problem. Got 61,000 on mine with no other problems.
Old Dec 31, 2012 | 05:53 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The factory had a run of the wrong valve guide seals install at the factory. Have your bike checked by VIN by a dealer. To correct the problem the heads have to come off. Check cam chain tensioners.
Big D6977
Aug 30, 2010 10:02 AM
eaheritage
Sep 27, 2009 01:32 AM
hobby4
Sep 15, 2009 09:22 PM
rayzager
Sep 8, 2007 07:23 AM
05flhr
Apr 24, 2007 11:57 PM
