When running longer rear shocks, do you guys go with longer fork tubes also to keep from messing up the stance of the bike from an appearance standpoint?
Does anything besides longer fork tubes add height back to the front to even out for longer rear shocks, for example would different springs or a longer spacer tube on top of the fork spring increase the sitting height of the front end?
Thanks, Dan
No, there aren't longer fork tubes. You don't worry about stance with longer shocks, its for a better ride and handling. Stiffer fork springs will sag less, so that might make the front ride a little bit higher.
There are longer fork tubes. With the 49mm tubes you can use Wide Glide tubes which are longer. This would help keep the rake at the original setting. Reducing rake could make the bike a little twitchy but for the most part with the factory rake raising the rear will make the bike turn in a little quicker. You will loose some inline stability.
