Exhaust Gaskets
Old Jan 21, 2013 | 11:06 AM
Krash26's Avatar
Krash26
Default Exhaust Gaskets
I'm looking to install the Samson Legend Street Sweepers on my FLD soon and I'm looking for new exhaust gaskets. The only ones the dealer is selling are the SE ones and I don't want those, so I'm looking at aftermarket.
Anyone got suggestions? I did see the Bikers Choice ones, spun stainless steel, so those could be it.
Old Jan 21, 2013 | 11:11 AM
ynots's Avatar
ynots
i used the se gaskets on my Bub 7 exhaust and they worked fine. I even pulled the exhaust and reinstalled it once without changing them.
Old Jan 21, 2013 | 11:13 AM
arejay86's Avatar
arejay86
out of curiosity, why dont you want the SEs? and also, sometimes, certain exhausts require either the OEM or SEs... just a lil heads up
Old Jan 21, 2013 | 11:14 AM
Northbound Southerner's Avatar
Why would you not want the SE ones? They are MUCH easier to deal with and seal fine...
Old Jan 21, 2013 | 11:29 AM
HD Pilot's Avatar
HD Pilot
Different pipes require different gaskets, my Bassani Road Rage required the flat SE type, but my stock pipes required the "flared/tapered" type.
Old Jan 21, 2013 | 04:16 PM
tomt's Avatar
tomt
SE gaskets is the way to go.
Old Jan 21, 2013 | 04:48 PM
mattVA's Avatar
mattVA
It all depends on if the head pipe is tapered or not. Stock is tapered, you can see it when you take it off. If not, SE usually work very well, if installed properly. There's a post by rounder on here with some good advise: https://www.hdforums.com/forum/dyna-...t-gaskets.html.
Having that socket really helps seat them evenly in the exhaust ports. That and some dish soap.
Old Jan 21, 2013 | 06:07 PM
Krash26's Avatar
Krash26
I've heard some complaints about the SE gaskets...few of my buddies that have used them complained they seat right. Was thinking about using the Bikers Choice stainless steel...thanks for all the input. I'll let you know what I end up using....
Old Jan 21, 2013 | 06:13 PM
Krash26's Avatar
Krash26
A few of my buddies have used the SE gaskets couldn't get a good seal and they were installing aftermarket pipes too. But, after reading that post MattVA, sounds like maybe they weren't installed right. I'll talk to Samson and see what they recommend too...whether to use flat or whatever. Thanks for all the input...I'll let you know what I end up using.
CookUltraClassic
May 8, 2019 09:47 PM
F86
Mar 24, 2016 03:15 PM
jharanin
Dec 14, 2011 06:40 AM
J DOG
Apr 1, 2008 01:14 PM
07FLHRCMarinePatriot
Jul 19, 2007 02:54 PM
