Longer shocks on Dyna?
Old Feb 8, 2007 | 01:49 PM
bendrider's Avatar
bendrider
1st Gear
Default RE: Longer shocks on Dyna?
Tdshepard,
Thanks for the information. I would also like to know the model of Ohlins shock you have on your bike. What is the shock length and did you get standard springs or have them put heavy duty springs on the shocks when you ordered them. Looks like a remarkable improvement on cornering clearance.
Bendrider
Old Feb 9, 2007 | 03:26 AM
tdshepard's Avatar
tdshepard
Unsubscribed From Forum
The shocks are type 36PRCLB. They have shocks listed for dynas but I got OHHD143 which is 13.5 inches long (adjustable lenght) and listed for XL sportsters. It came with a gold spring which was much too soft so I got black springs to replace. I weigh 200 lb.
Old Feb 9, 2007 | 11:30 AM
wadejesu's Avatar
wadejesu
Does anyone have a part number for Race-Tech front kit? I see on thier site they list a sf49, But the sales lady says they don't have anything for Dyna.
Old Feb 9, 2007 | 03:41 PM
tdshepard's Avatar
tdshepard
https://www.hdforums.com/m_833808/tm.htm
Since 06 and newer Dynas are 49mm you have to use a v-rod kit. It is an awesome upgrade.........
Old Feb 9, 2007 | 11:57 PM
someday69's Avatar
someday69
on my 02fxd I used the progressive suspension 440's cause they were 1/2" over,,,then in the front I used the race tech gold emulators & springs,,,with the dual brake kit,,and yes it all works great...
Old Feb 10, 2007 | 09:45 PM
Bug_Guy's Avatar
Bug_Guy
You could simply install a set of shocks off of an FXDX or FXDXT....those shocks were the most expensive and best performing shocks that Harley put on any stock bike. The lenght is 13 1/2" and they have all kinds of adjustments. Check eBay.
Old Feb 11, 2007 | 08:59 PM
blueglide88's Avatar
blueglide88
ORIGINAL: lolife
ORIGINAL: tdshepard
Ohlins on rear are 3 way adjustable. Race tech gold valves in front forks eliminate front end dive. Front Brembo caliper from v-rod increases stopping power. This bike sits level with me on it. Hauls *** and rarely touch a peg..........
Dude..............I just cant make any sense of this................................LO............ ............
[IMG]local://upfiles/19303/944924E177564AE2B10199322415DC64.jpg[/IMG]
I'm interested in increased stopping power. Does the Brembo vastly increase stopping power? How much did you pay for the caliper?
Old Feb 11, 2007 | 10:57 PM
cardboard's Avatar
cardboard
Could you not just have some 2 in over tubes installed on the front forks to raise it up ?
Old Feb 12, 2007 | 12:54 AM
jaxdwg's Avatar
jaxdwg
I have an 02 wide glide and put 1/2" longer-than-stock Progressives with their stock springs (I tried the heavy duty springs, way too stiff) and found the bike to handle better, the ride is waaaaaay better and I only drag pipes and frame occassionally now. I often wonder why others choose to go shorter. I raced for years and now I want what works best for the comfort and handling of the ride so I can put on the miles in comfort and so I can move when I get off lol---jack
Old Feb 12, 2007 | 12:03 PM
tdshepard's Avatar
tdshepard
here is my thread on the brembo mod
https://www.hdforums.com/m_1017368/tm.htm
