Homemade sissybar & side mounts?
It is the 30" "Old School" Attitude Stick from Cycle Visions.
I am just having a hard time swollowing the price tag of $125 and then another $85 for the side mounts from HD. Over $200 for some rod & plate steel...WTF! Not to mention the fact I would have to dechrome the side mounts.
So the wheels started spinning, Surely I can get some rod & plate steel, weld it all together, paint it black for less than $50.
Does anyone have the '06 side mount brackets that you can get the dimensions for me, or better yet trace it off on sdome paper for me. Need thickness also.
Thanks
https://www.hdforums.com/m_1244709/tm.htm
Jim
The hole mounting locations are at 3/8" and 1 5/8" from the bottom of the material you'll be using, the holes are 1/4 x 28 thread and the material is 1/2" square or round. as for the side plates, I'd trace out mine and send it to you but I've got a '98 FXDS and I'm sure it's different than yours.
Here's a couple of pictures of the sissy bar:
Gotta have something "pointy" on there, so...
And here's the aluminum mockup I made to give Bob an idea of what it was going to look like:
