Front turn signal relocation
Old Feb 5, 2013 | 11:33 AM
  #31
JRK5892's Avatar
JRK5892
mine are mounted under the lower tree, i made them... have done a few for forum members as well
here is my lighting in action
Old Feb 5, 2013 | 12:20 PM
  #32
INJEKTER's Avatar
INJEKTER
Originally Posted by PistolPete83
What does the internally wired bars have to do with the turn signals?
my signal wires run through the bars, nice neat and clean.... if i ran turns on the forks, wires would not run nice neat and clean.....so in order to get an even cleaner look, i put on the tiny led signals.......
Old Feb 5, 2013 | 01:25 PM
  #33
b2inUT's Avatar
b2inUT
Injekter, they can still be run internal. I didn't do the work, but did have mine relocated and the wiring is still internal.
Old Feb 5, 2013 | 07:53 PM
  #34
johnnyjellybean's Avatar
johnnyjellybean
Originally Posted by zimm
edit: Nice SLV, we must have posted at the same time....
Joker machine- you can mount them inboard or outboard.
Just bought these..... now I have to decide f I'm going to install them on the inside of the tubes below the light or the outside just below the top triple tree
Old Feb 19, 2013 | 03:58 PM
  #35
Jn499's Avatar
Jn499
6th Gear
Great ideas. Something I want to do before spring
Old Feb 21, 2013 | 06:47 PM
  #36
phatman218's Avatar
phatman218
Hey Johnny Jelly Bean, who makes those signals? I'm really diggin those....very subtle
Old Feb 21, 2013 | 07:20 PM
  #37
p51bombay's Avatar
p51bombay
Originally Posted by 128auto
Any led turn signal replacement bulbs require load equalizer. If you are adding leds to existing lights then no.
On the newer models, you can skip the LE if you only change the front or the rear, both ends and then you need one. I only have LED in front with these Kellermann bar ends and no LE.
Old Feb 21, 2013 | 07:22 PM
  #38
Chiledog's Avatar
Chiledog
Haven't read through all the posts, but use what you have plus one more left side handle bar mount. The handlebar mounts will attach to your lower triple tree pinch bolts once you drill the holes a little bigger. The additional mount costs about $12.00. Easy and no rewiring needed.
Old Feb 21, 2013 | 09:18 PM
  #39
little squirt's Avatar
little squirt
Originally Posted by '10 Wide Glide
hahahahaha, $243..............
Old Feb 21, 2013 | 09:39 PM
  #40
'10 Wide Glide's Avatar
'10 Wide Glide
here is the link for those:http://jokermachine.com/products/har...ights.html?p=2
