Really stupid basic question!
Old Feb 11, 2007 | 06:32 PM
Protrucker's Avatar
Protrucker
Default Really stupid basic question!
OK..........call me stupid!
I bought my wife an '05 Low Rider & want to hook up a battery tender, but don't see how to remove the battery cover. On my Street Bob there is a screw under the battery that holds the cover on, but the Low Rider is different. I removed the seat & still don't see how. What's the trick?
Old Feb 11, 2007 | 06:44 PM
piniongear's Avatar
piniongear
Default RE: Really stupid basic question!
My 2003 cover comes off like this:
Remove the rear bolt (bottom rear of the battery- this is a horizontal bolt into the frame)
Remove the rear top bolt (this bolt is vertical and will allow the battery tray to drop down)
Remove the cover.
Your 2005 is most likely very similar, if not exactly the same..........pg
Old Feb 11, 2007 | 06:48 PM
glide05's Avatar
glide05
My 05 came with a tender pigtail already in place - look around under the seat and make sure it's not there already.
Old Feb 11, 2007 | 06:50 PM
Protrucker's Avatar
Protrucker
Are you talking about the two bolts near the ignition switch? (the vertical one goes up?)
Old Feb 11, 2007 | 07:17 PM
glide05's Avatar
glide05
yes he means those 2 bolts, the one going straight up unter the swirch, and the blacked out bolt that's under the first one, goes straight in.
Old Feb 11, 2007 | 07:36 PM
Protrucker's Avatar
Protrucker
Got it. The pigtail is in place & tender hooked up.
Thanks for the help.
angellobo3
Mar 2, 2011 07:31 AM
mangiacavallo
Aug 19, 2009 06:16 PM
Sal C
Mar 21, 2008 07:36 AM
Protrucker
General Topics/Tech Tips
Feb 15, 2007 02:08 PM
kenn101
Apr 5, 2006 03:10 AM
