08 dyna no power
Old Mar 3, 2013 | 01:19 PM
just2low2tow's Avatar
just2low2tow
1st Gear
Default 08 dyna no power
i have an 08 dyna super glide....changes handle bars and ran wires through them..now i have no power to anything except the back light on the odometer and the red key light flashes...please help
Old Mar 3, 2013 | 01:29 PM
Psi23's Avatar
Psi23
Are you able to run a diag test? If you have a 08 I'm assume you have a diagram for the molex connector you dismantled to internally wire. I would go back and make are the terminal ends are all clicked tight and in correct position. Also if you did it smart you should have disconnected the battery. There is a small ground attached to the negative terminal for your ecu check to make sure there is a clean connection there. 3rd and worse case remove grips and controls check or pinch wiring.
Old Mar 3, 2013 | 01:55 PM
just2low2tow
1st Gear
thanks for the fast reply we just found that we pulled the harness from the ignition.
Mchad
Feb 27, 2015 06:43 AM
BlockHead96
May 17, 2010 10:10 PM
gymrat22
May 21, 2009 09:10 AM
plysat
Apr 20, 2008 09:24 PM
thatguy
Nov 14, 2007 12:35 AM
