On your Dyna, how have you been able to permanently install your battery tender pigtail? It just doesn't seem like I have enough room behind the battery cover on my 2012 Street Bob (maybe the mounting hardware for my battery cover bag is interfering--or maybe the pigtail that came with my tender is different and I need a slimmer one). I'd like to attach a power outlet for my iPhone charger for the longer rides... and my RPG launcher's laser sights.
I made the small slot in the upper left corner (looking into it) of the battery box where the cable goes through larger with a dremel, then ran my pigtail through that and out above the coil, wire-tied to the existing harness. Tucks nicely behind the coil when not in use. I would recommend wrapping it with some protector, like spiral nylon wire wrap, or the braided stuff, where it passes out of the box. The first one I had wore through and shorted out.
As JeffKill said - there should be enough room to tuck everything flat under the strap, including the fuse. It could be that if you have bag HW poking out of the back, that is interfering.
I attached mine to the battery and ran the pigtail out the left side of the bike. Just tucked the fuse under the strap that goes around the batter.
Me too. The fuse block is secure under the rubber strap. The wire runs aft to the slight cutout on the backside of the battery cover, then under the seat and out just above the electrical cover on the left.
You could be right about the battery-box bag hardware.
I run mine out of the inside front of the cover, then up along the frame to the front of the seat where it comes out
between the seat and tank right next to the power lead for my heated gloves.
Not exactly elegant, but it works and is easily accessed..
It'd be handy to be able to run GPS on my phone... etc. So I'd like to have a way to charge it. I was also thinking of installing a DVD and flat screen monitor on my handlebars. I think that's a brilliant idea.
