1356 Code
Old Apr 4, 2013 | 01:32 PM
docsg's Avatar
docsg
Default 1356 Code
I'm sure this has been discussed somewhere on the Forum but here is my issue: I have an '05 FXDLI with 33K on the clock. It has been well maintained and I only use Chevron or Texaco premium unless nothing else is available. Recently my bike keeps displaying a check engine code P1356 (rear cylinder combustion EFI). I can easily clear the code and it will stay off for a little while. But, if I accelerate hard the check engine light will come on and then go off when I let off the throttle. The bike seems to run fine but the code aggrivates the **** out of me. A local tech has suggested we change out the spark plug wires to the Screaming Eagle. I have the Stage I and a hotter cam (I think a 402?) that was added a couple of years ago by the HD-dealer. The tech does my interval services (every 5K) and changes the plugs each time with HD branded units. Does anyone have some suggestions as to what is causing the code to display? This Forum has been great in the past helping me to make decisions regarding my ride such as adding the True Track, the cam, etc. and answering tech questions as well.
Old Apr 4, 2013 | 01:48 PM
jimsflh's Avatar
jimsflh
P1356 is no combustion in rear cylinder.
Old Apr 4, 2013 | 01:49 PM
jimsflh's Avatar
jimsflh
got that here btw:
https://www.hdforums.com/forum/elect...tic-codes.html
Old Apr 4, 2013 | 04:21 PM
01ragtop's Avatar
01ragtop
Check the wires going to the rear cylinder's injector. There isn't enough slack in the wiring and the wires break inside the plastic insulation. Had it happen on my 06. I replaced the pins and added a couple inches of wire. Not saying that's your problem, but its a good place to start.
philb252
Sep 10, 2013 09:26 AM
harleyman6971
Sep 8, 2013 03:31 PM
HarleyGuy426
Jul 2, 2013 04:33 PM
Randall
Aug 12, 2009 02:35 PM
a21m
Mar 15, 2009 02:17 PM
