First Day with new Thunderheader...(56k warning)
Old Apr 10, 2013 | 02:10 AM
  #31
Al Marino's Avatar
Al Marino
6th Gear
Does the bike run any better with the exhaust wrapped? I used to use that 20+ years ago on the headers in my hot rods to reduce the under hood temps- but man was that exhaust hot!!
Old Apr 10, 2013 | 08:53 AM
  #32
gear.h34d.2012's Avatar
gear.h34d.2012
Originally Posted by macnab_sf
That pipe sure does look like it hangs low. I wonder if they changed something. Mine doesn't seem to be below the frame like that, but it could just be photo angle.
I'm pretty sure it's just the Thunderheader model made for the Pre-'06 Narrowglides. Any Pre-'06 I've seen running the Thunderheader is nice and low.
I couldn't honestly say because right after install I went to playing with my PCIII USB. That being said, I got her out on the backroads for the first time the other day with the new setup and hit ~115mph and still had throttle. Came up on a slow cager that same day going 60 to my 90 and I rolled it back to 100%. The last time I did that my TC88 didn't have anything left. This time? Passed that car like a fart in the wind with more to give.
(The pipes are hot though. I wouldn't dissuade you from wrapping, I'm loving it. Fuel economy also went up by about 25miles /tank)
TL;DR My stock TC88 is like a bat out of hell with this new setup (coming from Rineharts.)
Old Apr 10, 2013 | 10:15 AM
  #33
HooliganCycles's Avatar
HooliganCycles
Originally Posted by JCleary
Looks like you need to have a little custom work done... I ground a hole in mine, even with 13.5" shocks.
I had mine twisted and ceramic coated. Never scraped again:
How did you get it twisted like that? I like that a lot!
Old Apr 10, 2013 | 01:27 PM
  #34
Al Marino's Avatar
Al Marino
6th Gear
My 04 wg Is hooked up too, with a low restriction air filter, e3 plugs, python pipes, and a fuel programmer. It leaves my old 1200c in the dust, that had the same plugs, rejected carb, and screaming eagle slip ons without the baffles.
Old Apr 17, 2013 | 05:54 PM
  #35
gear.h34d.2012
UPDATE: Below is the skid plate I had my buddy fabricate for me, and it installed.
Click image for larger version
Old Apr 17, 2013 | 06:30 PM
  #36
Northbound Southerner's Avatar
Looks good. Is there any way to get those clamps behind the pipes? Can you rotate the plate and still protect the wrap?
Old Apr 17, 2013 | 07:42 PM
  #37
gear.h34d.2012
That's what we were going to go for, until we realized getting those clamps tightened down well enough with them behind the pipes would be a larger PITA.
Old Apr 17, 2013 | 07:54 PM
  #38
It honestly shouldn't be that bad. You just need a socket on a U joint. Turn the clamps over so you can get to the screws from under the bike. Take a whack...
Old Apr 18, 2013 | 12:23 AM
  #39
rockon's Avatar
rockon
Dammit that sucks! Is your bike lowered at all? My T-header is slung low like any other but I've never scraped it except when I actually got cut off in traffic and put the bike down.
Wrap is a pain for sure...I'm on my second wrap job in 4 years or so, and swore this 2nd time would be the last. Heat shields after this.
Old Apr 18, 2013 | 03:49 AM
  #40
Cascade's Avatar
Cascade
Can you explain that? I need to know what I am up to, because mine are wrapped also.
