First Day with new Thunderheader...(56k warning)
You can't exactly powerwash it...you'd damage it or peel the edges back, opening it up for more dirt and wind damage as a previous poster mentioned. For black wrap, you can at least paint over what dirt doesn't come out; periodic touch up is good anyway.
There's some prep required to get the wrap good and tight. With the black wrap I used the first time, I soaked it first, as is the general recommendation. Then when it dries it tightens up nice and snug. With my titanium wrap that's on there now, I think I just left it dry...soaking is messy and I didn't want to deal with it. To further exhibit my laziness, I did the second wrap job with the pipe on the bike...the first time I removed the pipe to install it. Differing opinions out there on which way is better.
Once a piece starts to unravel or tear, that's typically all she wrote. Sometimes you can repair it as the OP did, or unwind the wrap to that point and re-clamp it if it happened low enough on the pipe that you aren't removing the whole wrap job.
Lastly, the debate is open on whether wrap is detrimental to the life of the pipe. Some say the wrap can trap moisture and cause rust, or that it traps heat and causes the pipe to crack...but I saw neither when I removed my first wrap job after 3 years on the bike and plenty of time riding in all kinds of weather. Granted my pipe's paint probably kept the moisture out, but I saw no heat damage either.
So wrap can be kinda high maintenance, but damn if it doesn't look good.
http://www.hrpworld.com/index.cfm?tp...action=product
I never ride in the rain and I put some household plastic over the wrap when washing the bike, so I think I'll be ok for a while.
Also... Presure washers are a big no no on a bike, they'll put water where it doesn't belong.
http://youtu.be/trPtjry7ATs
