Performance Pipe for my Dyna?
Old Apr 9, 2013 | 09:18 PM
Red Dragons's Avatar
Red Dragons
Originally Posted by target64
I second that!!! my bike at 10 mph rolling will brake the tire loose and lift the wheel in second gear shift. and sounds good doing it.
I'm sure it does, but looking at your build it has NOTHING to do with the TH.
Old Apr 9, 2013 | 09:28 PM
target64's Avatar
target64
I was making a statement about FXDC rider quote about the thunder header in the beginning of thread.
Old Apr 9, 2013 | 09:33 PM
Red Dragons
Yes, I understand that...you were disagreeing with his statement that the TH leads to bad low end power when compared to the ST. But your statement about being able to break the tire loose doesn't prove anything about the TH's performance, given your engine build. With the amount of work you have done, ANY pipe would probably allow you to break the tire loose and lift the wheel in second gear.
Old Apr 9, 2013 | 10:06 PM
target64's Avatar
target64
had big shots and it would not do it. till after the exhaust swap to the th.
Old Apr 10, 2013 | 09:36 AM
spankdog's Avatar
spankdog
never mind. I type too slow .But I think most 2-1 pipes will make better low end power than a 2-2. Ive only heard good things about the TH. Its just too bad they're so damn ugly. But thats just my opinion. Lots of people like the way they look. Im planning on swapping my VH Big Shots for a Bassani RR. Kind of settling for middle ground on looks vs performance. And the short up sweep should keep me from dragging. If I could quit gouging my primary I would be good. lol
Old Apr 10, 2013 | 02:41 PM
Rustyrider's Avatar
Rustyrider
I have the D & D Bobcat 2 into 1...Sounds great and good performance..
Old Apr 10, 2013 | 03:42 PM
b2inUT's Avatar
b2inUT
looks good, man! is your FB lowered? Any issues with clearance--the road or the lower rear shock bolt?
Old Apr 10, 2013 | 06:08 PM
Northern B's Avatar
Northern B
Smile
RB Racing LSR, nice sound and good performance
Old Apr 10, 2013 | 06:55 PM
Iron A's Avatar
Iron A
I put a ThunderHeader on my 05 FXDXI last night it had a Screaming Eagle full system and stage 1 on it and tune from Hd . I just got off the bike and rode it all over.The usable power range is better,smoother and has more top end. I still can't believe the difference and on a basically stock 88. I thought thats the whole idea of merging 2 into one or a H or X merge. I don't understand the comment of the TH only being good over 4000 rpm?..
Old Apr 10, 2013 | 07:28 PM
Rustyrider's Avatar
Rustyrider
It is not lowered, I have plenty of ground clearance..It was lowered at one time until the rear tire ate the wiring harness from under the fender..
