Tank lift removed
Old Apr 13, 2013 | 10:34 PM
  #81
! rock103 !'s Avatar
! rock103 !
Old Apr 13, 2013 | 11:15 PM
  #82
DK Custom's Avatar
DK Custom
Platinum Sponsor
[quote=RANGER73;11160956]
Originally Posted by DK Custom
Can you keep me posted? PM me when they're available please.
Will do.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Apr 14, 2013 | 12:43 AM
  #83
Tony P's Avatar
Tony P
Looks better without the lift.
Old Apr 14, 2013 | 01:05 AM
  #84
118of1050's Avatar
118of1050
Default Which one...
Which one you like is all that matters!
IMHO, up is the way to go!
Old Apr 14, 2013 | 01:06 AM
  #85
20RoadGlidin's Avatar
20RoadGlidin
Originally Posted by Oceans08
Yea, it was real easy and inexpensive. This picture shows it a little better. I used a shelf bracket, just a steel strap used to join the end of one shelf to another. It already had 2 holes drilled in it 1.25 inches apart. I just had to drill them out bigger to match the bolt size on the bike. The strap goes on the outside of the tank tab. I used a black allen bolt with a nylock nut to attach one end to the tank. The original tank bolt stays on the bottom but I added 2 washers on each side of this bolt so it would be aligned with the strap on the tank tab. The washers should be the smallest outside diameter you can find because the tank tab will sit right on top of them. If you use larger washers then the lift will have to be taller. Hope this makes sense.
Assembley in order of position (left side as you face the rear of the bike):
Upper end of strap: Strap, tank tab, bolted together.
Lower end of strap: Strap, 2 small washers, bolt to original tank mount bolt.
I've had mine on for a year with no trouble at all. As you said, I think it's perfect.
Forgot to mention, there is a small washer on the outside of each bolt also. These are the two you can see in the picture.
Sweet. Thanks for the info on this one.
toastman
Dec 13, 2019 02:17 PM
Danzyg1
Aug 18, 2012 10:42 AM
animalnoll
Jan 8, 2011 09:59 PM
toastman
Mar 19, 2010 06:16 PM
rounder
Nov 20, 2008 09:33 AM
