Stage 1 confusion???
Old Apr 14, 2013 | 08:12 AM
rooti's Avatar
rooti
Your going to get a lot of misinformation and opinions here...do some more reading and find out for yourself what's best for your bike and where you want to go with it.
If you are on a really tight budget, just get the XEID's and call it a day (or whatever ones nightrider suggest)
If you know you are just doing stage one and want your bike the best it can be then find all the dyno tuners in your area and pick the best one. I think both dynovision and TTS have a deal where you can use the tuners tuner and pay a license fee (between 150-200) and then pay the dyno tuner around 300. You could have it dialed in and reflashed into perfection for 500 bucks without buying a tuner. No fussing and no playing around...just ride.
If you do buy a tuner and go another route, make sure you know what your buying...fuelpak and a few others will just adjust fuel and are NOT full tuners.
Old Apr 14, 2013 | 09:27 AM
deuce_streetbob's Avatar
deuce_streetbob
If you only want stage 1, then you need to take a look at the fuel moto micro tuner. It's only a few more bucks than the xieds and you get full support from Jamie and crew. The initial map they gave me ran unbelievably well, although just a touch of decel pop. One quick call, they walked me through an adjustment and know my bike runs like a dream. I also Luke the fact that if I decide to change my a/c or pipes to something different (unlikely, but u never know) then I can just call them again and ask for a new map. Great company with a great product. It's an easy install as well, with full blown up pictures of what you need to do. Do t let the low price fool you, for stage 1 it's a fantastic unit. I've tried other low end tuners, and none have worked so well right out of the box. Call fuel moto and end your search! You won't regret it.
Old Apr 14, 2013 | 09:40 AM
smitty901's Avatar
smitty901
STAG 1
Improved flow through Exhaust can be just pipes or headers also options from moderate to extreme you call your check book.
Increased air in take to feed that exhaust, Lot of options slight increase ,just a filter change or a whole AC change for Max flow you can get.
A Tune to match the mods you made.
Dyno best one shot you can get Expensive and not flexible over kill on a stage 1 of any level.
ECM dealer download. Ok but just bring you back to a pretty much stock Air to fuel not a budget buster but not cheap 100-150.
Xied's to fool o2 senors to add some fuel. Short term band-aid.
Piggy back fuel managers Most riders can install them on their own. Med cost some flex in making changes and adjustments most easy to us. But they have limits.
Real fuel managers, They flash the ECM. Much better results at a little higher cost.
Most riders can install them on their own. Many have canned maps available, so you can just flash one that will work for your style riding Example Power vision.
They offer the most flex and option.
If you go cheap short cuts you end up with a cheap short cut.
And likely will spend more and do it right latter anyway.
If you take your time pick pipes and headers You like and do it right you end up with a ride that fits your needs and style of riding.
Want a great deal on a stage 1 Fuel Moto package deal, give Jamie a look at least.
Old Apr 14, 2013 | 09:54 AM
rooti's Avatar
rooti
Good recap smitty..the only thing I disagree with is a dyno being overkill for stage one. Why wouldn't you want your bike to run at it's absolute best even with pipes and A/C?
The OP is not going to go beyond that, so in the lifetime of his bike, a small price to pay to have it dialed into perfection.
LouDiamond
Jun 29, 2015 09:38 PM
rowan
Jun 14, 2015 12:39 AM
martin1
May 20, 2014 08:42 AM
josemontesjr
Apr 29, 2010 07:16 PM
jtfrog
Exhaust System Topics
Mar 29, 2006 02:14 PM
