6th gear mph?
Old Apr 14, 2013 | 02:42 PM
Scaredofrain's Avatar
Scaredofrain
Level ground and no speed increase I'd hit 6th at 55 ish. If you need to be close to 80, WideGlide, you sure as h#ll have a different motor than I have.
Old Apr 14, 2013 | 03:16 PM
WideGlideFever's Avatar
WideGlideFever
Well its a 96, what do you have? I was kind of surprised myself but shifting into 6th any lower than approx 76-78mph really lugs the engine. I can run at 75mph at 3200-3400 rpm's (where I get the best mpg's also). If I shift into 6th at the same speed the rpm's drop to about 2800-2900.
Old Apr 14, 2013 | 03:53 PM
11bDad's Avatar
11bDad
Originally Posted by ! rock103 !
60-65 or so is the lowest I ever shift into 6th.
Same here.
Old Apr 14, 2013 | 03:56 PM
WG2011's Avatar
WG2011
The owners manual says 55mph so that's what i do hahahaha. Sixth gear man feels like i gotta be about 65 and higher. I Don't use it that often
Old Apr 14, 2013 | 03:59 PM
target64's Avatar
target64
55 mph in 6th. when the wife is on! 5th barks to much.
Old Apr 14, 2013 | 04:05 PM
soft 02's Avatar
soft 02
OP get some cams in it and 1st, 6th will be usable.
emerican19's Avatar
emerican19
80+ mph just for freeway cruising. If you're in 6th and you hit those weird pockets of traffic that go from 80 to 70 to 65 to 80 again it's too much shifting. Just long-term overdrive for me.
Old Apr 14, 2013 | 04:10 PM
smitty901's Avatar
smitty901
Used 6th at 60mph all day long on my 07. Only exception strong wind or long grade.
Same on the 2013.
Remember it is not a honda
Old Apr 14, 2013 | 04:33 PM
powerlab's Avatar
powerlab
Default mph
best mod u can do to that bike is put a 30 tooth sprocket on it..stock is 32.makes all gears so much more usuable...specially 6th...i believe its the first thing to do to these bikes..youl love it...
Old Apr 14, 2013 | 04:43 PM
Gommee's Avatar
Gommee
Devil's Advocate
Good to know, after I put the cams in, 6th was better, still 65-70mph (average cruising speed for me though). I have all of the parts for the 30 tooth, just gotta git r done!
