6th gear mph?
Old Apr 14, 2013 | 05:17 PM
Jeffs386's Avatar
Jeffs386
60+ for me to get into 6th
Old Apr 14, 2013 | 05:34 PM
Qdog002's Avatar
Qdog002
When I picked up my SGC, the service manager told me 65+ for sixth gear.
Old Apr 14, 2013 | 05:45 PM
artpe54's Avatar
artpe54
Mine used to lug all the time until I had it tuned.
Old Apr 14, 2013 | 06:31 PM
J.Sizer's Avatar
J.Sizer
80 miles per hour 6 gear.
Old Apr 14, 2013 | 08:14 PM
dirtdobber's Avatar
dirtdobber
Lugging the engine is using too low of rpm vs speed.
If the engine is below 2,300 rpm you are lugging, period.
60 mph in 6th gear is lugging. This is a single pin crank v-twin engine, not a flat 6 or inline 4 cylinder.
Yes HD has done a good job make these bikes smooth and masking the lugging feel.
With the new specs on the crankshaft as far as run out by lugging you are taking a risk of starting a problem.
It is your bike do as you see fit. who am I to convince you of anything.
Me, none of my HD's will fall below 2,300 rpm's
It is better to be at 2,800 rpms in 5th than it is running 2,000 rpm's in 6th.
just a thought.
Old Apr 14, 2013 | 08:16 PM
Wakko47's Avatar
Wakko47
Something must be wrong with mine...I keep nudgin the shifter up and it just never seems to get past fifth...weird...
Old Apr 14, 2013 | 08:26 PM
HooliganCycles's Avatar
HooliganCycles
i rarely use 6th unless on on the flat freeway at at least 80 mph. i agree 60 in 6th is definitely lugging it. i just took a 3 hour ride mostly freeway at about 75mph and never touched 6th gear
Old Apr 14, 2013 | 08:35 PM
Junkster's Avatar
Junkster
Cams made a difference in my shift points. Maybe the 30T next year.
Old Apr 14, 2013 | 08:47 PM
powerlab's Avatar
powerlab
Default gear
U guys would love the 30th...great upgrade
Old Apr 14, 2013 | 09:01 PM
soft 02's Avatar
soft 02
Wouldnt want my RPM's that high at 70. Good on a bagger or stock bike.
