Para cord Project
Old Apr 16, 2013 | 12:11 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by Jmee327
Just a little time overseas but i sure had a lot of down time...
Not really sure what knot it is but all i did was ran a loop the entire length of the forks and start wrapping as tight as i could all the way up. once you get to the top, you run the end through the loop and hold it tight while you pull the other end (should be on the bottom) with pliers...As you pull the other end of the loop, it will pull the top end under the wrap and that hold everything tight. Technically no knots....It hasen't moved at all yet
Nice project.
It's called "Common Whipping"
First, lay a loop of twine alongside the rope (handlebar end/fork tube), with the open end of the loop toward the end of the rope (handlebar grip/fork tube).
Then, beginning a short distance from the rope end (handlebar grip/fork tube), wind the twine tightly around both the rope and the twine loop. the last turn of the winding is inserted through the loop end.
Next, holding the rope (handlebar grip/fork tube) in one hand, pull the twine-end at the end of the rope (handlebar grip/fork tube) until the twine-end is about mid-way in the whipping. Clip both twine-ends and the job is complete. The whipping should be at least as long as the diameter of the rope (handlebar end/fork tube).
Old Apr 16, 2013 | 03:00 PM
Jmee327's Avatar
Jmee327
Exactly!!!
Old Apr 16, 2013 | 03:17 PM
SLV's Avatar
SLV
Looks similar to a hangman's noose....
Back in black,
Out of the sack,
I'm loose from the noose
That's kept me hangin' around....
Nice mod by the way, looks killer.
Old Apr 16, 2013 | 08:19 PM
jwguns's Avatar
jwguns
Thumbs up
Unique idea ! Nice job.
Old Apr 16, 2013 | 08:28 PM
elfnyc's Avatar
elfnyc
now make a whole bunch an sell me a pair of the grip ones !!
ill buy a damn set of those ---- im no rope master lol ur lucky i can tie my shoes
but hell yeah id buy a pair if u made them things
pm me if u wanna sell some
Old Apr 16, 2013 | 08:45 PM
scott504's Avatar
scott504
How many ft. of 5/50 did they each take to do?
Old Apr 16, 2013 | 08:51 PM
"Dutch"'s Avatar
"Dutch"
Did you gut the para cord on the grips?
Old Apr 16, 2013 | 09:02 PM
chris h.'s Avatar
chris h.
I've got access to OD green at work, I might have to try this out. Wish we had black though.
Old Apr 16, 2013 | 10:12 PM
fxdc rider's Avatar
fxdc rider
ive tried the same thing a while back and while they look cool, i found that the paracord was verry slick and i could not get a good grip on my grips with it.
Old Apr 17, 2013 | 07:40 AM
Jmee327's Avatar
Jmee327
That's while i ran the loop across the top...It runs across the backside of my knuckles and gives me a better hold..
