Para cord Project
Old Apr 16, 2013 | 07:22 AM
Jmee327's Avatar
Jmee327
Default Para cord Project
I just recently did a little para cord project on my street bob.....I had so much trouble finding someone with pictures or info so here is how it turned out if anyones interested.
Old Apr 16, 2013 | 07:38 AM
Northbound Southerner's Avatar
That looks good! Spent some time deployed have you? Amazing what you can do when you are bored...
Old Apr 16, 2013 | 07:41 AM
arkstreetbob's Avatar
arkstreetbob
Nice! What knot style did you use? My wife dose a lot of para cord bracelets.
Old Apr 16, 2013 | 07:54 AM
milesvdustin's Avatar
milesvdustin
We made an entire hammock out of that stuff on deployment once.....
Old Apr 16, 2013 | 08:47 AM
Jmee327's Avatar
Jmee327
Just a little time overseas but i sure had a lot of down time...
Not really sure what knot it is but all i did was ran a loop the entire length of the forks and start wrapping as tight as i could all the way up. once you get to the top, you run the end through the loop and hold it tight while you pull the other end (should be on the bottom) with pliers...As you pull the other end of the loop, it will pull the top end under the wrap and that hold everything tight. Technically no knots....It hasen't moved at all yet
Old Apr 16, 2013 | 10:13 AM
Northern Cowboy's Avatar
Northern Cowboy
Different. I like it. Well done.
Old Apr 16, 2013 | 10:14 AM
ghira75's Avatar
ghira75
Excellent job!! Was looking into ddoing something similar. You should post it under the sticky "HOW TO - under 50 bucks" thread, with a little description of the procedure.
Thanks for sharing.
Old Apr 16, 2013 | 11:15 AM
JRK5892's Avatar
JRK5892
that is awesome!
Old Apr 16, 2013 | 11:59 AM
Dynam1te's Avatar
Dynam1te
Thats unique as hell man! Nice work!
Old Apr 16, 2013 | 12:01 PM
elfnyc's Avatar
elfnyc
thats freakin bad AzS
