Turn Signal Relocation Question
Old Apr 16, 2013 | 06:22 PM
mooreman21's Avatar
mooreman21
Default Turn Signal Relocation Question
For those of you that have relocated your turn signal up front: how did you get the extra required length of wiring to move them? Bike info- '12 Wide Glide. Thanks for the replies!
Old Apr 16, 2013 | 06:52 PM
SLV's Avatar
SLV
The wiring junction under the tank has an extra place for pin connections. Gently pull it out from the front under-tank area.
Old Apr 16, 2013 | 07:16 PM
HD Pilot's Avatar
HD Pilot
If you get the HD Relocation kit, it comes with the wires.
Old Apr 16, 2013 | 08:09 PM
mooreman21's Avatar
mooreman21
do you just take the switch housings apart to undo the old connections?
Old Apr 16, 2013 | 08:12 PM
RANGER73's Avatar
RANGER73
NO, stay out of the switches when ever possible.
Old Apr 16, 2013 | 08:13 PM
RANGER73's Avatar
RANGER73
Because the wires come up the backbone, and your (I assume) moving them to the forks. There should be enough wire.
Old Apr 16, 2013 | 08:19 PM
TX Rebel's Avatar
TX Rebel
2012 WG front turns are hard wired to the switch. You have to cut the wires. Here is the instruction sheet.
Old Apr 16, 2013 | 08:33 PM
mooreman21's Avatar
mooreman21
Thanks Tex! That's exactly what I needed to know!
Old Apr 17, 2013 | 03:52 PM
condition1's Avatar
condition1
I'm doing this without the kit. Does anyone that used the harley relocation kit remember what the shrink tube was like that came with it? Was it open on both ends like standard shrink tube? I saw in the instructions that it say "encapsulating" but I'm not entirely sure what that means.
It just seems weird to me that the old wires would be shrink tubed with an end left open and I can't find any shrink tubing that's enclosed on one end. Sorry if this is a stupid questions, I'm learning all this wiring crap as I go.
Old Apr 17, 2013 | 05:30 PM
dogpig66's Avatar
dogpig66
It is open on both ends of the shrink tube. When you heat the shrink tube, not only does it shrink the tube, but heats an adhesive inside. As the tube shrinks, the adhesive melts and encapsulates the wiring and will ooze out the end slightly, sealing the tube.
