Removing the Belt Guard forward mount
Old Apr 17, 2013 | 07:56 AM
hardyf111's Avatar
hardyf111
Default Removing the Belt Guard forward mount
Do you guys know if there is any way to remove the front belt guard mount without removing or loosening the rear wheel? I cannot get my T-45 torx socket and driver in the space between the belt and the swing arm.
Is there a special tool?
Thanks in advance.
Old Apr 17, 2013 | 08:02 AM
128auto's Avatar
128auto
As far as I remember I used a short torx bit and a wrench to turn the torx bit. It's pain in the S, give that a try!
Old Apr 17, 2013 | 08:09 AM
! rock103 !'s Avatar
! rock103 !
It was a pain in the ***. Going carefully I got the torx bit in there enough to take it off without dropping the wheel.
Old Apr 17, 2013 | 09:46 AM
Hot6's Avatar
Hot6
I just did it this way last week. 1/4" boxed wrench on the bit and some downward pressure on ht top of the bit with my finger. Once the loctite is broken your home free.
Old Apr 17, 2013 | 03:42 PM
condition1's Avatar
condition1
I'm planning on going the torx bit in a wrench route, even easier would be torx bit in a ratcheting wrench.
What's holding me up is finding a damn t47 bit. I'm thinking the bolts are t47 and not t45. I started using my t45 but it is very loose and the bolts are pretty snug. I got scared of striping out the bolt head.
Old Apr 17, 2013 | 05:19 PM
Rat Trap's Avatar
Rat Trap
Originally Posted by Hot6
1/4" boxed wrench on the bit and some downward pressure on the top of the bit with my finger. Once the loctite is broken your home free.
That's how I did mine.
Old Apr 17, 2013 | 09:00 PM
Id.Fat Bob's Avatar
Id.Fat Bob
Okay...did this a month ago! I took the T45 bit and put it in a medium sized Vice Grip jaw(near the rear) and clamped the B-Jesus out of it! A little downward force and a healthy shove and SHAZAMM...out it came! My box end wrench was just too small to get the leverage needed! Anyway...it worked for me! My son had the bracket that holds just the belt guard and not the foot peg mount and that is what I put in its place! Now my FB is truely solo!
Liv42dayOK
May 26, 2017 06:44 PM
RazorFXDB
Oct 23, 2016 05:53 PM
jspoon
Apr 2, 2014 03:03 PM
bglaze
Jul 2, 2013 06:37 AM
my3sons
May 28, 2008 07:40 PM
