Change tires?
i charge $20/tire if you bring just the tire in or $40/per tire if i gotta remove them from the bike for you. that includes the requisite amoutn of dyna beads per tire, but doesnt include the $3 disposal fee i charge if you leave your tire here.
Takes a lot of time, but not longer than running to the Indi.
And in all honesty that has always been more of a hassle than doing it my self.
To break the bead, I use a four foot long 2x4 and put it under my work bench top, then put the tire on the ground below it and run a 2x4 from the tire where i want to break it down to the top 2x4 and just push down on the top 2x4. works easy. cheap.
Taking off the tire there is a sweet spot that you must find.
It is the area where the tire bead is not touching the rim edge and the rim center, (a little left of where the iron is in the picture) take your time finding this spot/Hole then just pry it up and rotate the iron slightly as you go.
Don't try to bite to much at a time, or you will not find the spot.
Putting it on the first side you don't need a iron, just man it on.
On the other side, getting the iron in just take your time.
Tie all your protectors together otherwise one will end up inside the tire.
Bob
Front tire needs replacing in the next six months or so, but that's the easy one.
Oh ya, use plenty of soap too.
