exhaust systems vs. cornering
Old Feb 21, 2007 | 02:43 PM
Raymond's Avatar
Raymond
6th Gear
Default exhaust systems vs. cornering
I think my new Street Bob corners even worse than my previous FXST softail & 2FXD's; especially right handers grinding away the exhaust & mounts. We don't have straight roads around So. Oregon so if you are not leaning these Harley's you are holding up traffic on our mountain (all) roads. (Such goes our infamous HOG chapter rides) I realize this isn'tmy Buell, but are there any quality/performanceexhaust systems that fit tighter up into the bike that allow moderate lean angles? I have already ordered a pair of WP shocks to help as well and looking at stiffer fork springs that won't mush out too to help. Thanks.
Old Feb 21, 2007 | 03:01 PM
Ratbasturd's Avatar
Ratbasturd
Default RE: exhaust systems vs. cornering
These D&D pipes have a slight up-sweep.
D&D Pipes
Old Feb 21, 2007 | 06:43 PM
iwant1's Avatar
iwant1
When I pulled off the SE 2 's I used to have on my bike, and then re-attached them, I noticed that I lost cornering clearance. I had inadvertantly angled them down slightly and rotated the slip ons so the bolts & mountswere contacting the ground. These two things made a pretty big difference.Have a look at where the contact is being made and then you couldloosen up the brackets and the slip ons and re-align to give you more clearance maybe.
I assume you wound upyour preload as well,wich will increase your cornering clearance. You should be scraping pegs before you scrape your exhaust system.
When Ireally want to get through the corners I shift my weight and drop my shoulder to the inside, which feels wierd on cruiser. Of course you can't hang off the bike like a sports bike,but it's surprising how much quicker you can take the same corners with the same lean angle when youmove the centre of gravity.
Old Feb 21, 2007 | 08:47 PM
steelcowboy's Avatar
steelcowboy
try turing up your rear shocks. I had the same issue when I changed over and the dealershp gave them a cpl cranks and problem solved.
Old Feb 25, 2007 | 06:18 PM
00glider's Avatar
00glider
Good advise above. However, I was grinding my SE IIs down all the time.
Better ground clearance was a big issue when I changed to V&H Pro Pipe 2-1, and I haven't come close to scraping it on my dyna anymore. When I looked into D&Ds, the Fat Fats look like they angled down, but Borzilla angled up. Just went with V&H and am happy.
freddy norway
Aug 8, 2014 01:43 AM
Bobbed Out
Dyna Parts
18
Oct 23, 2009 12:06 PM
Tnbrit
Oct 22, 2009 01:05 PM
dhtx1117
Feb 3, 2009 10:17 PM
Bama Harley
Exhaust System Topics
Jul 1, 2008 09:10 AM
