First gear trouble engaging
Old May 25, 2013 | 05:32 PM
ActionPaxton's Avatar
ActionPaxton
Default First gear trouble engaging
So I've had my 2008 street bob since middle april. only have put about 1,000 miles on it, no close calls or major bumps or anything like that and all of the sudden today first gear is having trouble engaging. I had to put some decent weight into getting it to engage at a stop light. It was sitting for about 2 days since I was carting my 4 year old around. Gears 2-6 work just fine with no slipping or anything. Matter of fact when 1st gear is engaged it doesn't slip or anything either. HELP! Thanks.
Old May 25, 2013 | 05:38 PM
dmpjr's Avatar
dmpjr
Check the linkage 1st..make sure everything is tight and adjusted properly.
Old May 25, 2013 | 05:40 PM
mbutton65x's Avatar
mbutton65x
Clutch adjustment?
Old May 25, 2013 | 05:43 PM
ActionPaxton
I'm gonna run out and double check the clutch and linkage, but at first inspection it was all good.
Old May 25, 2013 | 05:45 PM
dmpjr's Avatar
dmpjr
Mine was sloppy when I 1st got the bike..Shift lever was loose at the tranny shaft,
Old May 25, 2013 | 05:47 PM
ActionPaxton
I'm pretty mechanically challenged, however I know the basics. I'm gonna take a look and see what I can figure out. ANY suggestions from you guys are more than welcomed.
Old May 28, 2013 | 10:06 PM
ActionPaxton
So I just rode my bike and first gear is still having this same problem. I tightened the linkage and that didn't help it, and anything else I'm uncomfortable doing because I'm not sure what I'm doing down there. Does anyone have any idea what would cause this? This time when I went into 2nd gear it shifted hard, but after that it was smooth in all gears (except 1st)
Old May 28, 2013 | 11:06 PM
WS6 Formula's Avatar
WS6 Formula
If your stopped in neutral and it's also hard to get it into second gear, it may just need a clutch adjustment.
Clutch Pack Adjustment
Clutch Cable Adjustment
Old May 28, 2013 | 11:22 PM
ActionPaxton
I was thinking clutch adjustment too, but I don't stop in neutral when I'm in traffic, it's downshifting from 2nd to first or neutral to first. Still could be clutch adjustment though.
Old May 29, 2013 | 12:33 AM
Pistonman1's Avatar
Pistonman1
Only time I shift to 1st is when I am stopped.
