Cracking Open A 2013 FXDWG
Old Jun 1, 2013 | 10:37 AM
FASTnLOUDfxdwg's Avatar
FASTnLOUDfxdwg
Originally Posted by O-Town D
I also used the Heartland tool to do a cam swap a couple of months ago and I found that the 'fingers' on the puller were a little too far apart to fit into the cam bearing, so I closed them up just a tad with a small hammer until the puller would fit into the bearing. You may or may not have to do the same tweak. Other than that, it's a great tool and makes pulling/pressing the cam bearings a fairly easy job.
Watch the excellent S&S video, use your MoCo service manual, take your time, and it will all turn out good.
thanks for the heads up on the puller. I have the s&s video downloaded already and a service manual sitting here.
Originally Posted by ! rock103 !
Very cool, good luck bro! I dont see myself waiting for my "warranty" to be up before i do cams either. Im subscribing, post alot of pic and info about the install if u can!
I will take alot of pics when I do it. I am waiting on a couple odds and ends before I can install.
Originally Posted by bdtaylor1979
Sounds like fun. You are braver than I am tearing into a pretty much brand new bike.
I'm not scared to tear anything apart lol. When I bought my truck for 20k I had the whole motor tore apart 3 days later and now it is sitting in the driveway with tripple turbos that I built and dynoed 1117 rwhp on fuel only lol.
Old Jun 1, 2013 | 11:35 AM
Dynam1te's Avatar
Dynam1te
I'm looking forward to this build as well. Good luck!
Old Jun 1, 2013 | 12:35 PM
deuce_streetbob's Avatar
deuce_streetbob
When I first got my bike, I thought the idea of swapping cams was silly for the every day ride...not to mention a ridiculously expensive ordeal and time without the bike. Sadly, the more I read on here, the more I want to do it. Also, now that I have the service manual and watched the video of it being done, I want to do it even more. I love the idea of a winter project of replacing it myself...it just sounds fun as hell. Good luck on ur project though...I just wouldn't do it during riding season. It's bad enough when mother nature keeps me from riding!
Old Jun 1, 2013 | 03:20 PM
bdtaylor1979's Avatar
bdtaylor1979
Ah ok. My problem is I can take stuff apart all day long but putting them back together in working order is a totally different story lol. Dang!!! What kind of truck do you have? Do you have pics of the truck?
Old Jun 1, 2013 | 03:26 PM
FASTnLOUDfxdwg
I should be able to do the cams and start tuning it myself in a single day
Triple turbo powerstroke I believe there are some pics in my photobucket
Old Jun 1, 2013 | 06:01 PM
Redbeard's Avatar
Redbeard
I'm gonna stock with the sepst as tht what my dyno tuner prefers and he is really good with tuning. Also I keep herein about this trike pulley but can't find whih part number I would need for my bike.
This should be the part number for the 30T trike pulley from HD: 83595-11
Old Jun 1, 2013 | 06:49 PM
FASTnLOUDfxdwg
Thanks now I just have to decide what to do about the speedo. Looking like a Dakota Digital Gauge is my only option but do not want to spend $400 on a speedo.
Old Jun 1, 2013 | 09:15 PM
FASTnLOUDfxdwg
What is the general consensus on this? It says I would lose cruise and 6th gear indicator but dyna has no cruise and I must not have a 6th gear indicator because I have no idea what it is lol
http://www.dakotadigital.com/index.c...rod/prd238.htm
Old Jun 1, 2013 | 09:37 PM
O-Town D's Avatar
O-Town D
from G2 - "It says I would lose cruise and 6th gear indicator but dyna has no cruise and I must not have a 6th gear indicator because I have no idea what it is lol."
The '6th gear' indicator is the little green light in the speedo that turns on when you engage top gear.
Reading the description you posted of the Dakota adjustment module I'm guessing it's not 'plug-n-play' for your year Dyna - you might have to do some cutting/splicing/soldering. Any speedo adjustments you make have to stay within the Harley specs, otherwise you could lose cruise control (which you don't have anyway) or the 6th gear indicator light.
I've read other HDF members who have used the Dakota Speedo; maybe they can give you some tips. Or you might give Dakoto Tech a call for clarification/assistance. Hope you get it worked out.
Old Jun 1, 2013 | 09:40 PM
FASTnLOUDfxdwg
Im going to keep this pulley swap in mind but hopefully after these cams I will have enough torque to not worry about it.
