replacing lower belt guard
Old Feb 23, 2007 | 09:47 PM
Huebie's Avatar
Huebie
Default replacing lower belt guard
For those of you with passenger pegs, how did you remove the front factory bolt on the plastic belt guard. I only have about 3/4" between the outer primary cover and the passenger peg mount which is not enough room to hardly get a wrench in. Also the bolt is recessed so I cannot get a ratchet on it either. I removed the back two with no issue and that is what the new chrome guard uses to mount.
Help!
Old Feb 23, 2007 | 10:00 PM
ponte's Avatar
ponte
Default RE: replacing lower belt guard
I think I follow what you're trying to do. Try a socket attached to a 4" extension. You ought to be able to come up through the hole in the debis deflector and get at that bolt.
Old Feb 24, 2007 | 12:31 AM
Jeweler's Avatar
Jeweler
I don,t know if the 97 is like the 07,but on the 07 you do not remove the plastic deflector,only the two back screws. Slip the chrome one over the plastic one,clipping the overlap piece on the bottom and put the two back screws in. Hope this helps.
Old Feb 24, 2007 | 01:09 AM
ponte's Avatar
ponte
Sorry man.......didn't see the year and your sig and assumed it was late model. I'm sure someone has the answer for ya.
Old Feb 24, 2007 | 08:11 PM
carltex's Avatar
carltex
Used a socket and 6" ext on mine. I think there is a recessed area for it coming from underneath.
Mikey Ashie
Jan 9, 2013 10:30 PM
JoeEMT
Jul 2, 2010 05:30 AM
cdaxj
Mar 28, 2009 11:06 AM
dblcruzin
Jul 29, 2008 10:23 PM
bobbsterkid7
Jul 21, 2007 05:30 PM
