upper belt guard installation
Old Jul 18, 2007 | 10:56 PM
bobbsterkid7's Avatar
bobbsterkid7
Default upper belt guard installation
I purchased a chrome upper belt guard and would like to install it ASAP when it gets here. Can I remove the nut on the lower end of the shock and justslide the bolt out enough to get the guard off and the new one on, or do I have to put the thing on a lift to get this thing on, any help is appreciated!
Old Jul 19, 2007 | 04:38 AM
cHarley's Avatar
cHarley
Default RE: upper belt guard installation
Yes, just remove the nut and slide the bolt back a bit. It will hekp if you adjust the left shock to the max pre-load notch and the right shock to the min. pre-load notch to help take tension off the bolt.
Old Jul 19, 2007 | 11:03 AM
bobbsterkid7
so left side stiffest, right side softest? thanks!
Old Jul 19, 2007 | 11:14 AM
HOTLAP's Avatar
HOTLAP
I recently tookboth the upper & lowerguardsoff mine and I only had to remove the nutas the guard mountson the nut side of the swing arm,are you sureyours ison the bolt side?
I just installed a washer the same thickness as the guard and put the nut back on.
Old Jul 19, 2007 | 05:50 PM
Captain Morgan's Avatar
Captain Morgan
ORIGINAL: HOTLAP
yup same here. im going to do the lower when i get some more money saved up. and have my oil tank and battery cover painted to match when I do it.
Old Jul 20, 2007 | 08:43 AM
bobbsterkid7
mine mounts on nut side too, I was just checking to make sure if I loosened it and slid the bolt back a bit that I wouldn't mess anything up
Old Jul 20, 2007 | 07:13 PM
mr.hammond's Avatar
mr.hammond
yep.should be no problem.
Old Jul 20, 2007 | 08:34 PM
GothMetalGuitarist's Avatar
GothMetalGuitarist
If you pull any shock bolt without relieving tension by jacking the bike up you will not get the shock compressed enough to get the bolt back in. The bikes weight is compressing the shock. As stated though, if its on the nut side there shouldn't be a problem. Myself though, I don't do anything with the shocks unless I jack the bike...thats just me though.
Old Jul 21, 2007 | 12:29 AM
bobbsterkid7
well I got the upper an lower belt guards installed, was a breeze did it in 20 minutes after me, my father, step mom, future wife and step daughter went to a game, you can actually see the fireworks from my house, so we actually went to the game to see them up close, it was a hoot.
anyway, I loosened the right side shock bolt and pulled the thing completely out, it wasn't compressed, and it slid right in? are my shocks bad? mind you I have the lowered shocks, but I don't know if that matters?
let me know guys!
Old Jul 21, 2007 | 12:37 AM
GothMetalGuitarist
Your other shock probably kept it compressed enough that it didn't matter.
