FXDWG front fender
Old Feb 25, 2007 | 06:30 PM
Rick The Hawaiian's Avatar
Rick The Hawaiian
Default FXDWG front fender
Will an FXDWG front fender fit on an FXD narrow front end?
Old Feb 25, 2007 | 06:46 PM
jmpancoast's Avatar
jmpancoast
Default RE: FXDWG front fender
Look on Harley's online accessory catalog. They list the same fender for several models. Here is the description for the custom fender:
58998-83D
IN-STORE PURCHASE ONLY Contact dealer for pricing and availability.
Fits '70-later XL, FXD, FX, and FXR models (except FXLR).
This is what was offered when I search the fender for a 2006 fxdwg.
Old Feb 25, 2007 | 08:16 PM
R Racing's Avatar
R Racing
You would need to move the fender back and make a plate with spacers to attach to your frontend.
Jim
Old Feb 25, 2007 | 08:43 PM
Rick The Hawaiian
Thanks for the info.
Old Feb 26, 2007 | 12:35 AM
Rick The Hawaiian
I tried searching on the forum to see if anyone had modified an FXDWG fender to fit on an FXD. Could not find anything. Does anyone have pictures or know where I can get a plate/bracket to mount the fender? Thanks.
Old Feb 26, 2007 | 04:44 PM
R Racing's Avatar
R Racing
You would have to make the bracket. It would be pretty easy to do but you would need the new fender first.Because the wideglide fender is wider you would need to put the mount either forward or behind the forks.Take a few measurements and drill 2 holes in some 12 gauge steel to mount the plate to the stock location on the forks and mark the holeswere the fender will be mounted. You will need 4 spacers or a bunch of washer to extend out to the mounting points. I did something simular but different to mount a 06 wideglide fender to a early frontend. I will see if I can find the link to give you an idea.
Jim
Old Feb 26, 2007 | 04:48 PM
R Racing's Avatar
R Racing
Here is the link. The idea is the same but the hole patern is different on my application.
https://www.hdforums.com/m_1244709/tm.htm
Jim
Old Feb 27, 2007 | 12:00 AM
Rick The Hawaiian
Thanks for the info. I'll post a picture when I get it done. I just purchased some "new" sheet metal off a 2000 FXDWG.
Justind
Aug 2, 2017 09:38 PM
mill3rk
May 26, 2015 12:23 PM
PanHeadRich
Feb 17, 2013 01:26 AM
jordanball33
Jun 15, 2011 01:22 PM
JustDave71
Jan 21, 2010 03:18 AM
