88tc problem accelerating under load
Old Jun 18, 2013 | 05:15 PM
Robtarra39's Avatar
Robtarra39
THX for the replies, as for the mass sensor thingy, what I am talking about is the sensor that sits on top of the intake manifold , I am told It senses the vacuum in the intake and adjusts the timing accordingly, my bike is carb'd
tomorrow I plan I replacing the intake to carb seal and the accelerator pump diaphragm, I did try carb cleaner on the intakes and there was no change in RPM, last night I checked my sparkplugs and they looked new maybe a lean condition, so now thinking a carb issue , but I did rebuild the carb a couple of months ago, not sure where to go from here.
Old Jun 18, 2013 | 06:05 PM
Austin Dave's Avatar
Austin Dave
No problem prior to riding in the rain? If that is the case, then I check the air filter for being soaked. Moisture is always a suspect when having electrical issues.
The sensor you are talking about is the Manifold Absolute Pressure sensor (MAP). It will set a DTC12 code when it is faulty and/or out of range.
Old Jun 18, 2013 | 07:04 PM
Robtarra39's Avatar
Robtarra39
I have a service manual but could not find out how to retrieve the codes, all I know is it has something to do with holding the trip reset button on the speedo and ignition switch on and off or something like that
Old Jun 18, 2013 | 07:11 PM
Austin Dave
Look at the 'Sticky' How To *Hints*.....the procedure for pulling codes is there.....
Old Jun 18, 2013 | 07:24 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
"The manifold absolute pressure (MAP) sensor generates the engine load signal by measuring pressure (vacuum) in the intake manifold. The engine load signal is sent to the ignition module where it is used to help select the correct timing curve. Voltage readings decrease as manifold vacuum increases." Right from the service manual. Unplug the MAP sensor and spray some water displacement on the connectors and see if that doesn't help the situation. Don't know how much a new MAP sensor costs but that could be in your future.
Old Jun 18, 2013 | 07:32 PM
Robtarra39's Avatar
Robtarra39
I checked on pricing and it is 177.00 cdn, that's a lot of cash right now, I was told by a friend to just clean it and the parts manager at my local HD said he rarely ever sells them as they don't go bad.
Old Jun 19, 2013 | 02:43 PM
Robtarra39's Avatar
Robtarra39
Today I dove into the carb, was going to give it another cleaning to see if that solved the lack of power I experienced, then I took out the vacuum slide and noticed the rubber diaphragm had two small holes, so off to the dealer I went, gave them 72.00 and went on my way, installed it and gave the carb another cleaning, started the bike and now she revs up real nice and my power is back and MAP sensor was good after all.
Old Jun 19, 2013 | 02:48 PM
nevil's Avatar
nevil
Good to see you figured it out.
Today must have been carb day, I just rebuilt the one on my weed whacker.
Old Jun 19, 2013 | 02:54 PM
Grendel4's Avatar
Grendel4
Glad you fixed it but to people looking for Carb (vacuum) leaks...??
Please use a small, hand held Propane Torch. Unlit, of course. It works and it doesn't turn your paint and rubber into goo
If you don't have one. Borrow one or buy one
Old Jun 19, 2013 | 02:57 PM
Dynam1te's Avatar
Dynam1te
Ha! It is a carb day... got one on my 79' f350 givin me grief.... Glad you got yours figured out. I hate carbs. Cause I dont understand them....
