09 Street Bob will not start!
Old Jun 19, 2013 | 01:07 PM
dimenapenny11's Avatar
dimenapenny11
Stage I
Default 09 Street Bob will not start!
Rode the bike all day blinkers stopped working about 5 minutes before I got home... after the bike sat for an hour or so I went to fire it up, nothing. You can hear the fuel injection go when you turn the key, dash lights up, but I hit start and nothing... not a peep! Any suggestions?
Old Jun 19, 2013 | 01:12 PM
Good_Apollo's Avatar
Good_Apollo
Check battery and ground cables for tightness and corrosion, check all fuses
Clearly an electrical issue since the turn sgins went out. Did they just stop blinking or did they completely go out? Does the bike have security?
Old Jun 19, 2013 | 03:04 PM
Dynam1te's Avatar
Dynam1te
check battery connections then starter solenoid. My guess is it would be that if its not even making a peep. Power isn't moving past that first connection.
Old Jun 20, 2013 | 04:19 AM
cvfd17's Avatar
cvfd17
buy a new battery, problem solved
Old Jun 20, 2013 | 05:40 AM
loopie's Avatar
loopie
try jump starting off another battery, if it fires up battery is probally gone..
Old Jun 20, 2013 | 12:06 PM
knucklehed's Avatar
knucklehed
Same thing happened to me some months back, my front left turn signal took a **** on my to work, I parked and forgot about it, when I went to leave my bike wouldnt start. Check the fuses, check the battery. Use a multimeter and make sure you're getting clean connections. Took me a very long time to trouble shoot and went through about 12 blown fuses before I lifted the bike up and checked under the rear fender.Turns out my rear turn signal/brake light wires had come undone and were sagging so much that my tire had been chewing through them. Spliced new wires, shrink wrapped em, reapplied to the inside of the fender AWAY from any potential tire contact and now no problems at all.Anecdotal, sure, but I was experiencing the same issue with the startup as you are.
Old Jun 20, 2013 | 04:07 PM
joesride's Avatar
joesride
My buddies bike had the exact same problem.
deepak
Jun 29, 2019 06:51 PM
anglerman52
General Topics/Tech Tips
Jan 30, 2016 04:48 PM
Treyodum
Electrical/Lighting/Alarm
Sep 13, 2015 02:52 AM
JoeGrapes
Aug 14, 2009 06:12 PM
bobby5
May 1, 2007 06:45 PM
