Newbie questions
Old Feb 28, 2007 | 09:50 AM
hksb's Avatar
hksb
Default Newbie questions
Hi, I am looking at a 2006 Street Bob and really like it. I would like to use casted wheels instead of spokes. Would like to know if there is a standard wheel that will easily fit (plug and play format...) Thanks
Old Feb 28, 2007 | 11:28 AM
glide05's Avatar
glide05
Default RE: Newbie questions
Hmmmmm......
I don't own a Bob, but I think most SB owners would frown on replacing the laced wheels with cast. Everyone is different.
Anyway - the Superglide or Lowrider cast wheels should bolt right on with no issues.
Old Feb 28, 2007 | 09:04 PM
DGlide04's Avatar
DGlide04
Any late model Dyna cast wheel should be good. They can be found relatively cheap at swap meets and on E-bay.
Old Feb 28, 2007 | 10:36 PM
piniongear's Avatar
piniongear
If you buy cast wheels be sure to check the axle diameter before you plunk down that hard earned ca$h. Older models (2003 and before) had 3/4 inch axles and H-D changed later models to 1 inch. Just thought I'd mention that trap......pg
Old Mar 1, 2007 | 12:31 AM
Helix's Avatar
Helix
ORIGINAL: hksb
Maybe a Super Glide? Im sure any cast wheels of a glide would work on the Bob since they are both 100/90-19 57H . Heck as a matter of fact the XL1200 Low has Black cast wheels and is the same size as The Bobs. They would look good as well
Old Mar 2, 2007 | 05:53 AM
hksb's Avatar
hksb
Thanks for the replies. I like the look of laced wheels but sometimes getting a flat repaired is a bit difficult in my neck of the woods. But tubeless tyres are much easier to work with.
I am looking at getting a 2006 Street Bob and will probably finalise the deal shortly. I am just off-loading another engineering-parts-mechanic challenged British bike...
UPDATE: I just bought the 2006 Street Bob...
Old Mar 2, 2007 | 11:14 AM
soup48's Avatar
soup48
Go with what you want. I have a friend that has lace wheels and the spokes are rusting.
Old Mar 2, 2007 | 11:23 AM
lolife's Avatar
lolife
chang'em if you want.....make it youre own.......................LO...................... ............
navyshooter73
Wheels/Tires
Jan 15, 2018 09:51 PM
Jean-Philippe Taschereau
Wheels/Tires
Oct 25, 2017 11:51 AM
Elwaupo
Nov 19, 2015 05:27 PM
CRCRFT78
Sep 8, 2009 07:44 AM
Buddy WMC
Apr 30, 2007 06:24 AM
