Pushrod and lifter Questions
Old Aug 11, 2013 | 08:32 AM
rasmukri's Avatar
rasmukri
Default Pushrod and lifter Questions
So I am getting an abnormal amount of noise coming from my bike and I'm thinking it’s the lifters going out. But I just replaced the lifters when I put in new cams about 8,000 miles ago. So I am thinking that I may just need to get a set of adjustable pushrods and throw those in there and see if that fixes anything.
My question is how do you install adjustable pushrods? Right now I have the SE perfect fit rods that BTW I don’t know if they are installed upside-down or not. Yes I said that. Basically the SE rods have a rounded end and a tapered end, the stock ones have 2 rounded ends and the SE ones came with no direction on what way they go. Thus furthering the wondering of what my problem is.
Also if I need new lifters what brand do y'all recommend? Like right now I have HD stock ones but my bike is rather modified and pushes 97hp at the wheel. So should I be running something different and if so what?
Old Aug 11, 2013 | 09:27 AM
Mascman's Avatar
Mascman
I have the SE adjustables and still have a little more noise than I would like, but it runs good and seems fine.
I would think your tapered end would go towards the top...that is where most people see the rods hitting.
Personally I would like non adjustable pushrods. Only reason I installed mine was because I was hunting down a noise...which turned out to be the cam gear rocking on the crankshaft. It actually wore the end of the crank and I had to shim it.
I still hear some ticking but I believe it is normal for the 37h cams I have...plus I run a windshield so that makes it more noticeable.
Old Aug 11, 2013 | 09:32 AM
soft 02's Avatar
soft 02
OP what lifters did you use?
Old Aug 11, 2013 | 10:14 AM
rasmukri's Avatar
rasmukri
I know ticking is normal and that is all well and good. but this is more than normal.
like i got used to the norm tick sound but then one day i noticed it got louder and figured something has to be off.
BlockHead96
Engine Mechanical Topics
26
Jul 31, 2014 09:26 AM
stripeo
Exhaust System Topics
Aug 29, 2012 08:53 PM
biker69r
Aug 10, 2008 02:01 PM
chaos5
May 9, 2008 12:07 PM
combat_vet
Screamin Eagle CVO Models
Jun 7, 2007 10:03 PM
