Joker Machine turn signal HELP
Old Aug 23, 2013 | 09:53 PM
joneill's Avatar
joneill
Default Joker Machine turn signal HELP
I recently purchased the fork mount LED turn signals from joker machine.
I need help on how to install them. I can't seem to grasp on how I'm going to move them from the bars to the forks and still have the wire reach the turn signal switch since it seems to be hard-wired directly from the current bulb housing.
Has anyone done this on a 2013 Street Bob that can give me a step by step?
Thanks
Old Aug 23, 2013 | 10:41 PM
brandon95354's Avatar
brandon95354
im almost sure that you will splice the turn signal wires at the neck triple tree or in the neck of the frame. grab a wiring diagram and you will see the color of the wires you need. i do not think the wiring changed on the 2013s, i service manual will help its a great $70 investment
someone that has done this before will soon chime in.
Old Aug 24, 2013 | 02:20 AM
Cascade's Avatar
Cascade
I had them installed by the dealer, because the can-bus system can give some problems when hooking up LEDs.
Old Aug 24, 2013 | 04:54 AM
203Cree's Avatar
203Cree
You're going to tap in at the neck. You can terminate those wires coming out of the switch housing, as you won't need them any more.
There's not a lot to it really. Just remember you're going to lose running lights up front. If you don't have a wiring diagram, get one. Also, I would recommend going to the dealership and getting the factory connectors and hooking them up that way. No need to cut anything else in the harness that way.
And LED's don't cause any problems other than your dash light flashes a little faster.
tunafisher729
Aug 7, 2017 08:15 PM
SargeFirstClass
Jul 20, 2014 06:57 PM
joneill
Aug 23, 2013 11:15 PM
tinknocker17
Ironhead
May 17, 2010 07:53 AM
Matt115
Mar 31, 2006 04:13 PM
