Being jerked around
Old Mar 5, 2007 | 11:39 AM
BeavisRules's Avatar
BeavisRules
Default Being jerked around
Heres the scoop:
I bought a 06 Streetbob a little over a year ago. The bike has always hada "jerky" problem. Whenever I try to keep the throttle steady (like trying to go around 18 MPH) the bike lurches and sounds like it is sputtering.
Here is what I have done to try to fix it:
HD replaced the injectors with the correct ones
Screaming Eagle Slip-ons
Screaming Eagle A/C
Racing download
The injectors and the download have definately helped the situation but I can still feel it when I am going through a parking lot. I am thinking about taking it to the dealership and having it Dynoed but I don't want to pay for something and then have it still run like crap.
What should I do next?
Old Mar 5, 2007 | 11:45 AM
hd_sob's Avatar
hd_sob
Default RE: Being jerked around
I believe this is a high torque/low speed phenomenon. Mine does it as well in the lower gears (most noticeably in 1st). I'm not sure there is a cure.
Old Mar 5, 2007 | 11:51 AM
DyNaBoB's Avatar
DyNaBoB
do wut i did trade it in on a night train problem solved
Old Mar 5, 2007 | 02:01 PM
BeavisRules
ARGH!!
Old Mar 5, 2007 | 03:01 PM
harleyxlc's Avatar
harleyxlc
Don't have a solution, but mine does not have that issue and it doesn'tsound normal.
Old Mar 5, 2007 | 09:59 PM
Bighorse's Avatar
Bighorse
I can't believe that you haven't had the bike Dynoed. I have never heared of a harley that wasn't out of tune from the factory. Good luck!
Old Mar 5, 2007 | 11:12 PM
clayman's Avatar
clayman
Not sure how trading to a night train is going to help you. Any vtwin ive ever riden is jerky at slow speeds, you need to useyour clutch.
Old Mar 6, 2007 | 12:15 AM
06dynablack's Avatar
06dynablack
seeing its a 06 the primary chain should be ok but if its way loose you will get bucking also.
Old Mar 6, 2007 | 12:33 AM
BeavisRules
ORIGINAL: Bighorse
Unfortunately they charge extra to get it tuned right. Personally, I think it should run its best when it leaves the store but the EPA has ruined that for us.
Old Mar 6, 2007 | 02:03 AM
Rhubarb's Avatar
Rhubarb
If you are in 2nd gear, should be no jerking at 18mph.
My bet is on the primary chain being too loose... unless your bike is really out of tune.
