However, the filter did not come with a supply of spray oil for the filter, only instruction to apply oil in the pleats and let set for 20 minutes. I fortunately had some K&N oil spray left from previous filters and used it...otherwise I'm happy with the product!
Ya most of these filters do not come with a "recharge" kit. The manufacturer wants you to spend the extra money on the kit. However, these filters DO come precharged with oil. So it isn't necessary to oil a new filter.
I wondered if maybe it was pre-treated but couldn't be sure, so I hit it lightly again with the spray oil and let it set a few minutes to soak in a little.
Nowhere on the instructions did it say it was already treated, that would of been handy to know!
Oh, and FYI, if you change both the pipes and the intake for more free flowing parts.... you will probably need to also install some sort of EFI remapping device, i.e., Power Commander V., EFI tuner, or the likes.
Lots of choices out there so you will need to do a little research for what suits your needs best. The experts I spoke to (and also read up on in this forum) sugest that if you are doing just one side of the air in/out then no remapping needed, doing both will cause you to be to lean without it and that is not good.
Already got that part covered, I have the powervision sitting in my garage. Just waiting on the exhaust and trying to figure out which intake to get.
I have a heavy breather on mine and even with the rain cover it works great. actually runs better with the cover on. I have always been a fan of the S&S air cleaners as well. You can get a K&N filter for them and they sit nice and close to the bike. Still flow a good amount of air.
If you maintain the element oil, then fine dust isn't a problem.
This. K&N made intakes for our H-60s in the desert. Had to wash them every 3 - 4 days depending on flight hours. Oiled the crap out of them and they always collected everything.
Right above the gunner window.
Originally Posted by tstroud
Just don't over clean your K&N. They will pass a little fine dust until they get a coating of dust stuck to them. Once they get a little dirty the fine dust stops coming through. If you clean them all the time they are always passing the fines.
Please don't listen to idiots like this. If you don't clean your filter, your engine can't breathe.
Well, I don't know. My air filter does not look much like the one in your picture and besides, I'm pretty sure the topic on this forum is street ridden motorcycles, not desert operated helicopters. There may be a slight difference in the operating environment and the cleaning requirements.
I seriously doubt if any Street Harley will see as much dirt in it's lifetime as that H-60 sees in an hour.
You might be an expert on helicopter air filter maintenance and you might not be an expert on motorcycle maintenance. You absolutely don't know anything about me. I might not be an idiot.
