A/C recommendations?
Old Jan 8, 2014 | 05:58 PM
marcortez's Avatar
marcortez
Default Curious only
Originally Posted by tstroud
Just don't over clean your K&N. They will pass a little fine dust until they get a coating of dust stuck to them. Once they get a little dirty the fine dust stops coming through. If you clean them all the time they are always passing the fines.
How would you ever know if small dust particles passed by the filter element?
Old Jan 8, 2014 | 06:01 PM
tstroud's Avatar
tstroud
Remove the air filter and see if there is dirt on the throttle body or throttle plate.
Old Jan 8, 2014 | 10:24 PM
Stopit's Avatar
Stopit
I had this decision last year , I went with the S&S stealth . You can use your stock cover or go with one of 5 or 6 S&S cover styles for it and probaley others would fit also. It has a "stinger" / cone in the cover to direct air into the TB. It's the same money as the Big Sucker but comes in black.
Old Jan 9, 2014 | 11:46 AM
Grewe02's Avatar
Grewe02
Well, I don't know. My air filter does not look much like the one in your picture and besides, I'm pretty sure the topic on this forum is street ridden motorcycles, not desert operated helicopters. There may be a slight difference in the operating environment and the cleaning requirements.
I seriously doubt if any Street Harley will see as much dirt in it's lifetime as that H-60 sees in an hour.
Apples and Oranges.
Even K&N says not to clean the filter too often. http://www.knfilters.com/faq.htm#4
You might be an expert on helicopter air filter maintenance and you might not be an expert on motorcycle maintenance. You absolutely don't know anything about me. I might not be an idiot.
Sorry about the rant. You definitely don't sound like an idiot. My apologies. But honestly, that was a dumb thing to say.
Give K&N a call, they will tell you to keep the filter well oiled, and not to clean it too often, and not to let the filter get covered like you originally stated. Their filters are made to pass MORE air than a paper filter. With that comes more dust. That is the reason for the oil, it will catch the dust and pass the air. Obviously don't over oil it, but even the directions in the recharge kits say to use a liberal amount of the oil.
azgrumbles
Jun 22, 2017 11:58 PM
Webo
2014-2024 Touring Models
Oct 1, 2014 10:18 AM
Bigwillie
May 26, 2009 01:07 PM
FatboyRules
Exhaust System Topics
Jul 13, 2007 10:47 PM
DanDeuce
Dec 31, 2005 10:21 AM
