Stator removal?
Old Sep 17, 2013 | 05:04 PM
Sledhead83's Avatar
Sledhead83
2nd Gear
Default Stator removal?
I'm replacing the stator on my 06 dyna low, just wondering if this can be done without taking the inner primary cover off, have the comp. sprocket bolt off and I cant' get the rotor and stator to slide all the way off the shaft?
Old Sep 17, 2013 | 05:24 PM
maddghost's Avatar
maddghost
Yes you will need to get that inner primary off, unless you use mud's mod which I can't find right now. Use lots of lube on the wire harness when you pass it through the primary case.
Old Sep 17, 2013 | 05:39 PM
Sledhead83's Avatar
Sledhead83
2nd Gear
I thought I read on here that you could. But maybe that was a different year or model. Whats mud's mod? Thanks for the advice.
Old Sep 17, 2013 | 05:46 PM
maddghost's Avatar
maddghost
I can't find that page, but it involves grinding the meat on the inner primary casing enough to slide the rotor out. As i recall it was from about 10 o'clock on down to about 5:30. I recommend buying the new bolts and gasket and do it right- there will be less risk involved. You should have a manual with you doing this job for torque values and procedure.
Old Sep 17, 2013 | 06:06 PM
Sledhead83's Avatar
Sledhead83
2nd Gear
I found the lip on the inside of the inner primary cover def the lazy way. ill just take the cover all the way off. I have the bearing and seal, just didnt wanna take it down if it wasn't nessary.
Old Sep 17, 2013 | 08:08 PM
maddghost's Avatar
maddghost
gOOD MAN!
aviscomi
Dec 2, 2015 09:52 AM
jackinthebox
Nov 26, 2013 08:03 PM
nkauf21
Jul 21, 2010 03:33 PM
07RoadHawg
Jul 17, 2009 04:00 PM
heavypic
Jul 13, 2009 04:55 PM
