have a rattle / noise
Old Sep 28, 2013 | 03:12 PM
bbqbrisket's Avatar
bbqbrisket
Default have a rattle / noise
I seem to have a rattle coming from the front of my wide glide.
I checked the heat shields even though I didn't think it was them because the rattle is too deep sounding.
tapped my knuckles all over the front fender and up front where the regulator is and nothing.
oh, and one more thing. It seems to only occur when I have backed off the accelerator. IE. when I put a load on it
all is OK. But when I back off and kind of do a low cruise about 25 to 35 let say going down hill, it starts up.
any other ideas
thanks
Old Sep 28, 2013 | 04:09 PM
DJY's Avatar
DJY
mine does same thing mostly when cold.
Old Sep 28, 2013 | 04:10 PM
WideGlideFever's Avatar
WideGlideFever
Tank bolt?
Old Oct 1, 2013 | 12:42 PM
Jason Oates's Avatar
Jason Oates
Not to hijack your thread, but I have an '05 Wide Glide and just recently there is a slight rattling coming from the front/side. Like you, I've tried to knock around anything that could be considered loose coming from these areas, but nothing. It seems to only happen when going from 1st to 2nd and in increasing the throttle.
Any other thoughts for either of us?
Old Oct 1, 2013 | 12:59 PM
Wranglin4Life's Avatar
Wranglin4Life
I would just go over and check as many of the bolts as you can to eliminate something minor like that. It does sound like something has just worked it self loose over time.
Old Oct 1, 2013 | 01:58 PM
FreddyP's Avatar
FreddyP
I also have a look at the front motor mount even though you describe it as a "deep sounding" rattle.
Old Oct 1, 2013 | 02:26 PM
rooti's Avatar
rooti
wideglidefever has the answer...tank mounting bolts...tighten them with 2 wrenches
Old Oct 1, 2013 | 02:31 PM
Tcar1's Avatar
Tcar1
6th Gear
It might be your gas cap.
Old Oct 1, 2013 | 04:01 PM
hddan502's Avatar
hddan502
Originally Posted by WideGlideFever
Tank bolt?
What he said!
Old Oct 1, 2013 | 09:22 PM
Jason Oates
I'll definitely check these out tomorrow. It sounds like it would be well below the tank (exhaust heat shield?) but I'll see if anything seems loose and I'll check back here. Thanks again!
