Switchback ?'s
Old Oct 22, 2013 | 02:08 PM
rauchman's Avatar
rauchman
Default Switchback ?'s
Greetings,
My wife and I just got a pair of Switchbacks and have some questions.
At some point, I'm going to focus on engine hop ups, but would like to get some other things squared away first.
I would like to increase the front brake performance. My wife and I are coming from sport bikes and find the Switchback's front braking performance somewhat lacking. I realize the rear brake is utilized more on an HD, but I'd still like to improve the front brakes. I'm already going to add braided steel lines. I looked through the braking subforum on this site also, but still had questions. I'd like to know...
  • Is there a way to add a 2nd rotor to the right side of the rim?
  • If so, what would this entail?
  • If so, what caliper setup to use that's better than a stock HD caliper.
  • Is there some setup that would add braking performance to just use one rotor?
Backrest - I bought the parts to add a backrest from the local HD dealer. Mike, the service guy was great and warned me it would be involved. After looking at what needs to be done, I have some questions...
I have to remove the top bolt of the rear shock. The instructions say to completely do one side of the bike first, then the other.
  • When removing the top shock bolt, will the bike remain held at the correct height from the shock from the other side I'm working on?
  • Do I need a lift to do this correctly?
I have to remove the bolts that hold the quick disconnect bobbins for the luggage. The screws use a Torx head, which I'm fine with. One of the screws does not seem to be unscrewing and is just twirling the entire bobbin w/out coming undone. I noticed there was some kind of Loctite on the screw.
  • Do I need to heat the screw somehow to release the Loctite, or is there another suggestion?
Shop Manual - Where can I find a shop manual for a 2013 Switchback? The dealer doesn't have one, and HD's site also does not have one listed.
Appreciate the help!
Thanks,
Ken
Old Oct 22, 2013 | 03:08 PM
upflying's Avatar
upflying
The Dyna Defender came with double front discs. Someone at a higher pay grade will have to chime in whether the right fork leg will fit the Switchback.
Old Oct 22, 2013 | 03:19 PM
b2inUT's Avatar
b2inUT
Nope. The new Dynas have 49mm forks. Get the other fork leg for a Fat Bob... don't know what else, though.
I had to order my manual from my dealer.
Old Oct 22, 2013 | 05:59 PM
spencer75's Avatar
spencer75
You can buy a six piston caliper and increase your braking performance without needing to change the other lower leg. That'll work well and save you some ca$h for other things.
As far as the shocks, yes - take one off at a time. The bike will not sit at the same height once you take one side off (because it will then be only supported by half of the rear suspension). Hit Harbor Freight (or pep boys, etc) and get a small bike lift (around $50-$80) to take the weight off the swingarm. That will help make things alot easier, even with normal maintenance and cleaning. Just make sure you strap the bike down to the lift so your new baby doesn't fall over.
Old Oct 22, 2013 | 06:48 PM
chris h.'s Avatar
chris h.
After we had the master cylinder rebuild kit installed the front brakes seemed to work much better.
Old Oct 22, 2013 | 09:05 PM
Mike650's Avatar
Mike650
you probably ownt be able to add a caliper and rotor with out changing the wheel and fork legs. and fatbob legs wont work as the switchback has inverted forks. your best bet and cheaper is get some performance machine 4 or 6 piston calipers. and why your dealer doesnt have manuals in stock at all times is beyond me. walked into my dealer and walked out with a manual 2 minutes later.
Old Oct 23, 2013 | 06:12 AM
sysint's Avatar
sysint
Alternate front end is the solution. You have HD Showa right now and you cannot fit another disk on that. Maybe start talking to someone like motorcycle metal for a possible change but if you are going down that road might as well get the rear suspension redone too. When you add that up plan for 3-5k more.
I only have about 3k miles on mine as I got it mid August. Here are the issues I have:
1. Front brake weak.
2. Windscreen allows buffeting on the helmet at over 60mph.
3. High speed turns are a little unstable.
4. At times the vibes get a little excessive in the bars. Granted, usually at higher than posted speeds.
5. Suspension is better than other Dynas, but still average.
6. Front fender needs a better design.
I think I'll stabilize the motion on it, improve the front caliper and lines and windscreen and instead of taking on a suspension redo I'll put that into head, fuel system, cam and exhaust improvements.
If you want vastly improved suspension and braking this is better solved with a different motorcycle.
Still, I like it a lot. Very nice idea they have on this model.
Old Oct 23, 2013 | 06:39 AM
1HD1C's Avatar
1HD1C
quick and very usful upgrade is the pads..
a lot of the guys on the switchback owners site
have switched out to EBCs..
marked improvement in stopping power..
The EBC part numbers are:
Front FA-457HH
Rear FA 458HH
also if you experience the bad vibration from 2400-about 3300rpm that
about 70% of these bikes have there is an extremely cheap fix for it..
i cant post direct link here BUT you can google search for
"switchback owners" and it should be the first site that comes up...
LOVE MY SWITCHBACK!!!
Old Oct 23, 2013 | 07:36 AM
rauchman's Avatar
rauchman
Thanks for all the info. Can anyone recommend a 4 or 6 piston caliper?
Old Oct 23, 2013 | 07:22 PM
Carl '69's Avatar
Carl '69
Originally Posted by Mike650
you probably ownt be able to add a caliper and rotor with out changing the wheel and fork legs. and fatbob legs wont work as the switchback has inverted forks...
No it doesn't.
Braided brake lines & better pads will work a treat. If that don't cut it, a aftermarket 4 or 6 piston caliper will work wonders.
Mchad
Oct 6, 2018 06:35 AM
Egldr05
Aug 4, 2011 10:17 PM
jb1023
Jan 31, 2010 04:42 PM
MZBuckeye
Feb 20, 2009 10:11 AM
