Another jack thread! Just a quick question
Old Oct 29, 2013 | 03:57 PM
Justinh0822's Avatar
Justinh0822
Default Another jack thread! Just a quick question
Read a lot about the red sears mod but is this jack any better? and can this be modded as well? Does anybody have this one with any input? I have a 2011 FXDB
http://www.sears.com/craftsman-profe...&blockType=G14
Old Oct 29, 2013 | 05:16 PM
bobnehoc's Avatar
bobnehoc
That one is a different style jack and looking at the pictures I would have to say no the mod will not work. You need to get the width of the pads to see if it is wide enough to work on your frame. The red jack was to narrow that is why they started to mod them and put the pads on the outside. I did the mod on mine but I am not sure what the width is and I am working the late shift tonight so I can not take any measurements until tomorrow night as I have to be back for first shift in the morning.....
Old Oct 29, 2013 | 05:27 PM
marcortez's Avatar
marcortez
Default Idea??
If you can swing the cost, a J&S lift fits a Dyna right out of the box.
No tweeking.....no modifications....it fits.
Bottom line.....you will not find a better lift.
I have one....it is rock solid steady.
http://jsjacks.com/products-page/pro...torcycle-lift/
Old Oct 29, 2013 | 05:51 PM
jmb79's Avatar
jmb79
How wide do the pads have to sit in order to fit a dyna? I guess the best measurement that counts is between the inside edges of the pads.
Old Oct 29, 2013 | 05:57 PM
ExDucRider's Avatar
ExDucRider
You cannot modify that one. Just get the red and do the modification and done with it. Just make sure you use a 1/2" "GRADE 8" bolts.
Old Oct 29, 2013 | 06:01 PM
marcortez's Avatar
marcortez
Not sure who your asking but the J&S jack lift is 13 3/8th inch, pad inside to pad inside.
ExDucRider's Avatar
ExDucRider
Yes this J&S jack fits right out of the box. But for $399 plus $70 shipping, it's just not justifiable for me. Especially if I can buy a Craftsman for $84.00 plus less than $20 nuts and bolts. Did I mention that it is pretty solid as well.
Old Oct 29, 2013 | 06:47 PM
marcortez's Avatar
marcortez
Looks good to me.....
Choices are a good thing.
Good luck to you.
Old Oct 29, 2013 | 07:37 PM
jmb79's Avatar
jmb79
That's what I was asking. Thanks.
Old Oct 29, 2013 | 08:19 PM
JustsoIcanupvotethis's Avatar
I don't have any experience with the Craftsman jack. I do have the Kobalt 3/4 ton motorcycle and atv lift I got from Lowes. It works perfectly with my 2013 Super Glide.
http://www.lowes.com/pd_11304-20535-...AID=1024155226
