What CAM
Old Nov 14, 2013 | 11:21 AM
Sharkman73's Avatar
Sharkman73
I have the Wood TW-222 cams & LOVE them! They come on strong at 2,000 and run out very nice in upper rpms as well.
They perform way better above 4,000 than the SE 255s. The Andrews 48H cams are a good choice for low end grunt as well, and will also run out better than the SE 255s.
Old Nov 14, 2013 | 11:25 AM
Sharkman73's Avatar
Sharkman73
Originally Posted by johnd5412
i have used 3 different cams and i wanted power in the same range as you.
in terms of performance i rate them in the following order
stock cam
se 255
andrews 54h
wood 555
That's comparing apples to oranges. The SE 255s are a low rpm torque cam, the other two have totally different profiles to perform better with other mods and higher rpms.
For that low rpm range where you wanted your power, you should have been comparing the SE 255 to the Wood TW 222 & Andrews 48H.
Old Nov 14, 2013 | 11:26 AM
domenicp7's Avatar
domenicp7
Originally Posted by SC-Longhair
Lots of folks who have put the 255s in their dyna say they are awesome up to about 4k rpm.
There is a dyno thread in this forum. You could check it out, as a guide. See which cam puts power where you want it. Your numbers will vary because no two dynos are the same.
You are correct.
I seldom need to take it above 4k off the line she pulls like a freight train.
Old Nov 14, 2013 | 11:35 AM
Sharkman73's Avatar
Sharkman73
I will add also that if you're changing cams for performance, it's only going to be as good as your exhaust system & you'll be wasting money if you have slip-ons or short system that doesn't perform well. Don't make the same mistake I did....do exhaust first or at the same time. Don't buy an exhaust system for looks...buy for real performance.
People that say their short shots or slip-ons perform well with their aftermarket cams have never seen the real performance gains of a good system. Not slamming anyone for their choices, just speaking from experience.
After the cam install, I wasn't please with the gains, so I decided to do exhaust also.
I gained 9hp & 7tq on the dyno just from changing out the stock head pipes with V&H slip-ons to a D&D Fatcat. If you want to get the most out of the money you're going to spend doing cams, get a good exhaust system too....I recommend a good 2-1 if you want real world performance gains.
For example short shots look awesome, but they perform like ****....especially for low end torque, which is why you're wanting to do cams in the first place. You want torque, you want a 2-1 or if you want to stay with a 2-2 system, the longer they are the better.
Old Nov 14, 2013 | 01:17 PM
domenicp7's Avatar
domenicp7
I agree on the shorter pipe hurting performance but one variable is a good tune and I have a good tune done by one of the best in the DFW area.
Old Nov 14, 2013 | 01:35 PM
Sharkman73's Avatar
Sharkman73
You're right...there is no substitute for a good dyno tune done by a good tuner. Even with just a stage 1, but especially if you change pipes & cams or other mods, a good dyno tune makes all the difference in the world.
Also, I will add...nothing looks better than short shots!
Old Nov 14, 2013 | 07:45 PM
arkstreetbob's Avatar
arkstreetbob
I have the Andrews 48H. For me it is just right. Very good lowend and mid. Dont run my bike at past 4000 but have just to see and it is still pulling hard past 5000. I like riding in the hills in 4th gear. 40 mph to 60 mph in hills and never change gears. I have been on freeway at 70 and hit it to get past someone trying to drive in the same lane as me and 70 to 100 is real quick.
Old Nov 14, 2013 | 09:17 PM
Sharkman73's Avatar
Sharkman73
Sounds about like my Wood TW-222s...,they start pulling like a train about 2,000, but run out well in higher rpms also. I rarely go past about 4,500, but when I have it's still pulling hard all the way through. I couldn't be happier.
48H cams have similar characteristics to the TW-222 from everyone I talk to, especially when combined with a good 2-1 pipe like both of us have.
Also, I can cruise comfortably at 55-60 in 6th and still have good pulling power with no lugging when I twist the throttle.
Old Nov 14, 2013 | 10:54 PM
arkstreetbob
Before I changed cams I had to be at 65 for 6th. Now 55-60 and I can use 6th. Andrews 48H cams are great.
Old Nov 14, 2013 | 11:39 PM
bfuller14's Avatar
bfuller14
Could anyone tell me what would be a good cam for a 08 FatBob with S/E Heavy breather and the the Vance & Hines short turn downs? Also a tuner for it?
Thank you
