Red hot head pipe
Old Nov 18, 2013 | 09:02 PM
nevil's Avatar
nevil
I ran NGK's for awhile just to see if there was any differences. None that I could tell, but changed them back to the stockers anyway.
Old Nov 19, 2013 | 08:35 AM
Sharkman73's Avatar
Sharkman73
Just go to your local parts store and pick up some Champion RA8HC plugs.
(Champion makes HD plugs, and the RA8HC is the same plug as the HD 6R12).
Originally Posted by marcortez
Great information Shark.
Your call on the what is going on is right on.
I was right in the middle of putting back in the OEM plugs like you said, but with my "all thumbs" syndrome in full gear....I dropped one and it broke the tip off. Sheet!!
So that is out, as I don't have another set and it's 700 miles to San Diego at the local H-D dealer.
Surely there has to be scads of guys who have changed out from OEM to a NGK plug.
In the furtherance of our knowledge base, I would be interested to hear of any similar problems with using a non OEM plug.
Old Nov 19, 2013 | 09:05 AM
Ridewva's Avatar
Ridewva
Following your suggestion, I pulled both plugs. See attached photos.
The "junk" you see on the threads is anti-seize lube......
Just a heads up, you're not supposed to apply anti-sieze to coated plugs like NGK.
http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf
Old Nov 19, 2013 | 12:28 PM
marcortez's Avatar
marcortez
Thank you.....that is good information to add the ever growing stockpile of knowledge.
Now I am going to jump on ordering a torque wrench!!
Old Nov 19, 2013 | 01:47 PM
Ridewva's Avatar
Ridewva
LOL I learn something almost every time I visit this site!
3/8 for sure but may as well get a 1/4 and 1/2 also if you can. The quarter inch for things like primary cover screws and 1/2 for axles. Make sure to keep them set on zero when not in use. Harbor Freight wrenches seem to be as good as Craftsman or Kobalt (probably made by the same Chinese factory) and are very reasonable. http://www.harborfreight.com/catalog...=torque+wrench
mshred
Jun 10, 2019 07:14 AM
tar_snake
EVO
Aug 26, 2017 07:29 AM
Midgard
Aug 21, 2012 02:25 PM
so165
May 6, 2008 10:49 PM
guitarenigma
Aug 20, 2006 01:52 PM
