One throttle cable
Old Aug 20, 2012 | 10:29 PM
Midgard's Avatar
Midgard
Default One throttle cable
So I got my apes on and now I am only running 1 throttle cable.
I have what feels like a 1/4 turn of slack in the throttle (it's actually 1/8th of a turn) but its quiet a bit.
Can I eliminate this? If not I guess I can live with it. But.. my bike has also stalled on me twice now. Once at idle at a red light, and other while on the throttle it sputtered then hooked up for a second and then seemed like it was starving for gas and died/stalled - both times it didnt want to fire right back up, I actually had to give it some throttle as I hit the ignition.
Any help here would be really appreciated.
Old Aug 20, 2012 | 10:34 PM
camo36's Avatar
camo36
there should be a cable adjustment screw up by the throttle in the cable...? is there none? it may be fully compressed...just screw it out.
Old Aug 20, 2012 | 10:40 PM
Midgard's Avatar
Midgard
its as for as it can go
Old Aug 20, 2012 | 11:19 PM
redmosquito1's Avatar
redmosquito1
You gotta balance the 2 cables so take the slack out and allow the cable to return. Play with both adjusters so that it has little play and snaps back. I adjusted mine tonight so that I had just barley any slack, but thats how I like it. I think both adjusters are about half out.
I don't think the throttle adjustment would affect the way the bike runs, once the throttle bodies close its running off the whatever the idle is set at, I don't know for certain but would assume there is an idle control valve in there that may be out of adjustment or dirty.
Old Aug 21, 2012 | 12:12 AM
camo36's Avatar
camo36
Im on my phone and can't see what bike you have, but is there any adjustment at the bottom of the cable down by the carb/manifold whichever you have? Usually an adjustment at that end also. If there's not and your upper adjustment is maxed out...not too much you can do...wrong cable I guess.
Old Aug 21, 2012 | 11:50 AM
Midgard's Avatar
Midgard
Thnx for the feedback - I am only running 1 cable - it's adjusted as far as it can go.
Thinking I might need a different cable - thnx
Old Aug 21, 2012 | 02:22 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I have a single cable on one of my bikes. It has a little bit of play burt not enough to cause the bike to stall. It was a cut to length at the time of install with an internal throttle.
Old Aug 21, 2012 | 02:25 PM
soft 02's Avatar
soft 02
Do you have the spring installed in the mount at the throttle body?
Ozark Joe
EVO
18
Dec 20, 2015 09:07 AM
c-note
Jun 17, 2014 07:59 PM
KDagostino
Apr 8, 2013 08:44 PM
Hazim
General Topics/Tech Tips
Oct 29, 2011 01:31 PM
champ198
Nov 10, 2010 06:42 PM
