New cams with no dyno-tune?
Old Nov 19, 2013 | 03:03 PM
JayOhh's Avatar
JayOhh
Cool New cams with no dyno-tune?
Ok. So I ordered a 2014 FXDF which will be waiting for me in april/may ( whenever the ridingseason starts up here ).
I live in the northern part of norway in a small city ( 50 000 people ). We do NOT have a Harley dealer here. The dealer I ordered mine from is in a very small village 4 hours drive from here, and they don't have a dyno bench. The closest Harley-dealer with a bench is like a 12-14 hours drive away.
So... I ordered my bike with K&N filter, D&D exhaust and a powervision. I wanna have them put in a set of SE204's aswell, but will the Autotune basic of the Powervision be able to handle this?
I know I should get it duno-tuned, but thats not an option, at least not right away. So am I better of not getting the SE cams? Is it really a noticible difference between stock and the 204's? Or is it all in your heads?
PS! I've ridden my FLSTSB for four seasons now. K&N filter V&H Competition-series exhaust and a PCV with autotune. It was never dynoed, but ran close to perfect with the help of the Autotune, stock cams though....
Please chime in.....
Old Nov 19, 2013 | 03:04 PM
JayOhh's Avatar
JayOhh
Ohh... I forgot. Powervision will come from the dealer, so I don't know if Fuelmoto ( seems to be the common answer ) will help me out here....
Old Nov 19, 2013 | 03:38 PM
Foxster's Avatar
Foxster
The trouble with most tuning systems and tuners is that they don't know what to do with cams. They tend to do a reasonable job of fueling but timing is just not touched.
Your problem will be that SE204s have 8° of timing built into them and need a specific timing map to cope with this, otherwise your timing will be retarded by between 4° and 8° across the piece, leading to a significant loss of power, rather than the power gain you were looking for.
Considering you are a long way from support, I'd go with a SEPST instead. You can then put the canned map on for SE204s plus open air cleaner and exhaust. You will be 95% of the way there and you can finish it of with some Smart tuning if you like.
Old Nov 19, 2013 | 03:42 PM
digger2255's Avatar
digger2255
Better get some good advice from some forum guys i have a 2014 flhtk and it dont need them it has the stage 1 kit and makes 94 ponies on the dyno.
Old Nov 19, 2013 | 03:50 PM
KEYBEAR's Avatar
KEYBEAR
You can call or e-mail fuel moto and they will send the tune close to your need .
(Dealer should have this done already) Then the Auto Tune will take care of the rest .
It will work just fine and any problems just e-mail Fuel Moto .
Old Nov 19, 2013 | 03:52 PM
Foxster's Avatar
Foxster
Methinks your dyno guy had his finger on the scales there. Stock they have been dynoed at 76HP by Fuel Moto. Stage-1 adds 10%, so typical would be around 84HP. Pretty unlikely you are going to find another 10HP without cams.
Old Nov 19, 2013 | 04:22 PM
128auto's Avatar
128auto
Get a Powervision from Fuel moto and preload a map. I have used their in house map for my 107 build, it runs like a top without dyno tuned.
Old Nov 20, 2013 | 05:08 AM
JayOhh's Avatar
JayOhh
Yeah as I said. Im buying the Powervision through my dealer. I'm picking the bike up With AC and pipes installed, and driving it home. So they're gonna Mount the PV before I ger there.
So I don't know how helpful Fuelmoto is gonna be. They're just a normal distributor of Dynojet Products right?
I could wait With the cams 'till I og on a longer trip this summer, I just wantet the extra umpfh from the getgo.
So how big is the actuall difference With the cams. Not asking for dyno-numbers here.
Old Nov 20, 2013 | 05:56 AM
ghira75's Avatar
ghira75
why do you have to buy the powervision from your dealer? just get it from fuel moto. the extra shipping/tax is worth having the correct tune, IMHO.
btw, the PV is just plugged into the diagnostic connector, it's a 30 seconds job if you take your time and don't need a dealer to plug the pv into a connector.
Old Nov 20, 2013 | 09:35 AM
nhrider1's Avatar
nhrider1
You should be fine with the PV. DynoJet should have a base map that will get you close, and the PV will adjust the tune from there.
Why don't you use the autotune set-up you already have with the PV? The PV can use autotune...not sure if the cable will be the same. Check it out on the Dynojet web site.
