integrated tail light question
Old Nov 29, 2013 | 05:20 AM
666streetbob's Avatar
666streetbob
Originally Posted by SudHD
I just plugged them in and didn't push them in all the way I can pull mine off if u buy that one and I'll send u a diagram. It is very simple. And for the price u can't beat it. Looks bad ***.
I did end up buying it . Youre right for the price you cant go wrong! If you dont kind getting a diagram if appreciate it!
Old Nov 29, 2013 | 06:44 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by 666streetbob
Youre talking about the pin connectors for the turn signals? I took my twilight and fender off last night and was looking at it all, how does it all get wired in?
There's a wiring diagram in this Ebay auction
Black = ground
Yellow = right turn
Blue = left turn
White = running
Red = brake
I have the 2006 Dyna Dom and Intl Models (Except FXDWG, FXD35), Instruments & Indicators wiring diagram in my database
Ground = black
Right turn = brown
Left turn = violet
Brake = red/yellow
Running = blue
Old Nov 29, 2013 | 02:11 PM
barcoeng's Avatar
barcoeng
This is the one I have. So much better than stock! I just cut my pins off the old stock turn signals and reconnected them with some connectors and heat shrink. Took maybe 45 minutes all together.
http://www.ebay.com/itm/Smoke-LED-Ta...81eab8&vxp=mtr
Old Dec 1, 2013 | 07:52 PM
666streetbob
Originally Posted by FXD2003Rider
There's a wiring diagram in this Ebay auction Black = ground Yellow = right turn Blue = left turn White = running Red = brake I have the 2006 Dyna Dom and Intl Models (Except FXDWG, FXD35), Instruments & Indicators wiring diagram in my database Ground = black Right turn = brown Left turn = violet Brake = red/yellow Running = blue
My stock harness has 6 wires? Theres an extra orange wire?
Old Dec 1, 2013 | 08:15 PM
SudHD's Avatar
SudHD
6th Gear
Default How do u attach an image?
Trying to send pic
Old Dec 1, 2013 | 08:16 PM
SudHD's Avatar
SudHD
6th Gear
Hope that helps.
Old Dec 2, 2013 | 04:56 AM
FXD2003Rider
The bike's stock wiring harness has 6 wires indeed.
The orange/white wire is used on international models to feed the tail light as a parking light (key switched to acc).
Old Dec 2, 2013 | 06:10 AM
666streetbob
The bike's stock wiring harness has 6 wires indeed. The orange/white wire is used on international models to feed the tail light as a parking light (key switched to acc).
Gotcha. So that wire can be cut and capped?
Old Dec 2, 2013 | 06:12 AM
666streetbob
Trying to send pic
Pic didnt work? Do you want to try email? Captivatethreads@gmail.com
Old Dec 2, 2013 | 07:38 AM
FXD2003Rider
Not sure what your plan is. I assume you do not longer need the OEM tail light circuit board.
I'd recommend not to cut the connector that goes into your circuit board from the H-D OEM harness.
If i'm not mistaking, you should be able to use the AMP Multilock serie 6-Wire cap housing (OEM 73106-96BK) + the AMP Multilock serie Male terminal (OEM 73190-96) (both available on-line or at the dealer's) to make a new taillight sub harness that mates with the stock H-D connector that runs from the OEM harness under the rear fender into the tail light area (see image below).
