Weak throttle response
Old Dec 6, 2013 | 07:44 PM
SLV's Avatar
SLV
So, is the idle lumpy and awkward just before the bog?
Old Dec 6, 2013 | 08:46 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
For information sake, the crankcase is a "dry sump" case and is typically a table spoon of oil in it while the engine is operating.+1 trying to accelerate prior to the rear cylinder starts firing again . Try rolling a little bit using the clutch just prior to "green" so the speedo sensor picks up the motion and the rear cylinder starts firing.
Old Dec 7, 2013 | 01:48 AM
Red Dragons's Avatar
Red Dragons
Originally Posted by iDodgimus
this is my bet, if it only happens after idling for a while...
"During hot idle, or when the motorcycle is
off-throttle and running at hot temperatures,
EITMS shuts off fuel to the engine’s rear
cylinder, leaving it to idle on the front
cylinder only. Without combustion, the
rear cylinder and exhaust header will begin
to cool, bringing relief to the rider (and
passenger) soon after. Once the rear cylinder
cools to a predetermined temperature, or as
soon as the rider accelerates, both cylinders
resume operation. And by maintaining
constant rpm during rear cylinder
“shutdown,” transitions between one and
two cylinder operation are nearly seamless.
EITMS is purely for rider comfort. When it
activates and “shuts off” the rear cylinder, it’s
not because the motor is overheating. It’s
designed to reduce the heat radiating from
the rear cylinder to the rider"
Where did you find that? I wouldn't consider it for rider comfort, as I've hardly noticed any decrease in heat when it turns on. I assumed it was to prevent overheating of the rear cylinder which is always hotter than the front. However, I feel like the extra load put on the front cylinder pretty much negates the benefit to the rear. I've been considering turning it off on my FB.
Old Dec 7, 2013 | 11:22 PM
shovelheadroad's Avatar
shovelheadroad
Originally Posted by suthpaw22
I have a 2014 Dyna Super Glide. I bought her new 3 weeks ago. I noticed yesterday and then again today when I sit at a long red light there is a bog and a weak throttle response when the light turns green. Anyone else experienced this? This is my daily driver and I drive about an hour each way and there are a bunch of lights, I feel the heat coming off the motor at long lights, but could this be an overheating issue?
The twin cam runs lean by design so consequently runs hot. An easy fix is to install an inline enrichening device or IED.
Simply a set of wires that plug in inbetween your o2 sensors and computer...plug and play.
What it does is make the computer richen your air/fuel ratio which drops your engine temperature dramatically.
read more about them here:
http://sales.nightrider.com/
Tons of riders here swear by them. Me included.
Old Dec 8, 2013 | 12:49 PM
iDodgimus's Avatar
iDodgimus
It was in some HD brochure I found on google...
speedydog5
Jun 17, 2015 09:57 AM
shore
2014-2024 Touring Models
31
Sep 15, 2014 09:11 PM
ptl203
May 21, 2014 05:44 PM
jamala00
Aug 31, 2013 10:57 PM
