06 street bob primary belt question
Old Mar 15, 2007 | 09:23 PM
moonsfmc's Avatar
moonsfmc
Default 06 street bob primary belt question
Does this model have a automatic adjustment on the primiary drive ....
Old Mar 15, 2007 | 10:04 PM
ROADTRAIN's Avatar
ROADTRAIN
Default RE: 06 street bob primary belt question
Yes
Old Mar 16, 2007 | 12:59 AM
DougsDyna's Avatar
DougsDyna
What he said........... Yes, but the primary has a chain.
If you are referring to the drive belt, you have to maintain that manually. I believe the tension is 10 ft lbs.
Not a problem if you aren't experiencing any weird vibrations, etc. Check the belt for cracking, breaks and abnormal wear patterns (alignment).
DougJ
Old Mar 16, 2007 | 08:52 AM
moonsfmc's Avatar
moonsfmc
Thanks for the help i was talking about the chain but i see where i should have explained alittle better but thansk for the help.
edjack
Feb 28, 2016 04:20 PM
Sailrider 1
Jul 8, 2013 07:53 PM
KopeX
Feb 10, 2012 05:55 AM
drake95th
Aug 3, 2006 01:47 AM
Denman SA
Aug 11, 2005 03:40 AM
