Fuel pump.
Old Dec 28, 2013 | 02:39 PM
stbob07's Avatar
stbob07
Well tracked it down to the fuel pump. I think. When I hit the on button I get 12 volts to the wires that plugs into the pump.
Old Dec 29, 2013 | 12:36 PM
stbob07's Avatar
stbob07
So turned out it was the system relay. Found a old thread on here with the exact same system as my bike had. So for 15 bucks a replaced starter and system relay. Problem seems to be gone.
Old Dec 29, 2013 | 01:16 PM
03geetee's Avatar
03geetee
Originally Posted by 03geetee
Check also to see if this pump has a fuse or relay in the black box on the left of your seat. These bikes shake alot so stuff like this can rattle a little loose or need replacing.
Just a thought.
JTR
Boom!
JTR
Old Dec 29, 2013 | 01:33 PM
stbob07's Avatar
stbob07
I went into the dealer to pick up the relays and talked to one of the techs. Expanded what was going on and first thing out his mouth was systems relay. Apparently these thing go bad pretty often. Wtf.
Old Dec 29, 2013 | 05:10 PM
03geetee's Avatar
03geetee
Like I said you have a bike that shakes, heat, and exposure add time and you have a recipe for this. No biggie cheap fix just keep an extra with you and check/clean your fuses often.
JTR
Old Dec 29, 2013 | 05:40 PM
peter deering's Avatar
peter deering
Tks will replace next time im at the dealership and purchase a couple of extras
Old Dec 29, 2013 | 06:44 PM
Freebirdsride1's Avatar
Freebirdsride1
good for you I'm glad you made the repair your self, with the help of others input.
Old Dec 29, 2013 | 10:42 PM
Junkster's Avatar
Junkster
Dielectric compound is your friend.
Old Dec 30, 2013 | 01:23 AM
stbob07's Avatar
stbob07
. There is that crap on all my fuses ect. Was surprised it went bad. Just glad it was a easy fix. Thought I was gonna half to get into the fuel pump.
Old Dec 30, 2013 | 09:21 AM
Junkster's Avatar
Junkster
It stops corrosion not parts failure. Who knows where the relay was made. **** happens. Glad you got er fixed.
68shelby
Jun 4, 2017 05:42 AM
jmn1960
Sep 17, 2015 08:02 PM
Ohio UC
Apr 18, 2011 09:54 PM
clarkchriston
Mar 3, 2010 09:41 AM
clarkchriston
Mar 1, 2010 04:07 PM
