Handlbar question
Old Jan 1, 2014 | 11:02 AM
okbill's Avatar
okbill
Default Handlbar question
Been looking for new handlebars for my 03 wide glide. Does this model have wiring running thru the bars? I don't see any but thought I'd be safe and ask first. I'm looking for something that will use my factory wiring without having to cut and splice. Pullbacks of somesort about the same height or a little shorter than the factory mini apes. Any suggestions and pics? Oh ya, Happy New Year to all of you!!
Old Jan 1, 2014 | 11:30 AM
Crazy's Avatar
Crazy
I'm really not being a wise-*** here. You could look at your bike and see if the wires are run internally.
Old Jan 1, 2014 | 11:39 AM
Robtarra39's Avatar
Robtarra39
No the wires are not internally wired from the factory, unless someone changed it in the past, as for the control wires there is plenty, you will need to pull it out of the backbone if you need more length, I am not a fan of the cut and spliced wires, I would take the time to remove the connectors and feed the wire internally then re-install the connectors, makes for a nice clean factory lookand solder joints to worry about breaking or corroding
Old Jan 1, 2014 | 05:26 PM
TonyGinFla's Avatar
TonyGinFla
I agree. The tool to push the pins out of the connectors isn't expensive either.
Old Jan 1, 2014 | 06:13 PM
Ndfastln's Avatar
Ndfastln
I've found that the small screwdriver in an eyeglass repair kit works well, is cheap and can be found most anywhere. Taking the wires out of the plugs is easy and you can find videos on Youtube of exactly how to do it.
srhen
Apr 21, 2016 05:15 AM
2014streetglide
Apr 9, 2011 05:18 AM
smokinfromshootin
Nov 20, 2010 09:01 PM
Dyna2007
Dec 27, 2009 07:34 PM
BlackFLHR
May 19, 2009 03:10 PM
