I am installing Aberon adjustable levers. The brake lever went fine, but the shift lever installation has resulted in only able to start in neutral despite various cable adjustment.
Still not to sure. I got the lever adjusted and not to bad, but the bike will not start unless in Neutral. It goes into neutral quite easily. Trust me I tried all the possible settings and adjustments of the clutch cable.
I used to like to stop at a long street light and turn off engine, but leave in gear so I could fast start. I then put in clutch and it started. Now I can only start in neutral . Will not start while in gear, unless I re adjust the lever to all the way out( setting 5) . This negates why I bought it . There seems to be at least a narrow window that works the neutral switch, but will not start with the clutch lever pulled all the way in.
I am hoping some members could help. Did I screw something up? Is there another adjustment to let the bike start while in gear.
Sounds to me as if the lever simply wont release the clutch enough. However adjusting that particular lever is some thing i know nothing about. Have you measured the movement on the clutch it self to see if it does indeed release in the primary.
you problem is the lever. pull it off and you will see why. you could adjust the cable for the rest off your life and it wont do ****.. They say the lever will fit all years models Total bullshit . on your standard lever is a tab that will let you start in gear your new lever has not got the tab to make the safety switch work, either get used too it or re wire the safety switch
Either the new lever is missing the clutch interlock switch tab or you didn't know the switch was there during install and you damaged it. In either case, the bike will only start in neutral. Look inside the clutch perch when the lever is near the bars; you should see a rubber covered switch. There's your trouble.
Or, you could adjust the clutch cable until the friction plates burn up. But it still wont start in gear
Sounds to me that the lever isn't compatible and not pressing your safety neutral switch... like loopie says... As i recal the only bike you can only start in Neutral is a Suzuki...I may be wrong but it's the only metric i ever owned that did that.
I installed the Oberon clutch lever but before I bought it I asked if it would be compatible with the clutch safety switch. I was told that it would be fine except maybe when the lever was adjusted all the way in, closest to the grip. I needed the adjustment all the way in and when I installed the lever it did just as I was told. Due to a problem with my hand it was more important to get the adjustment right than be able to start in gear. So, the lever worked as described to me.
It probably goes back to when my bikes were kick start and I just got into the habit of starting in neutral, but to this day I never start the bike in gear. Just don't think it's a good practice.
it is the lever as stated above the stock one has a tab to engage the clutch compressed button on the perch, the new lever does not, so the bike thinks it is in gear and will not fire
